CD104 reads CDRs but not CDs - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th May 2013, 06:18 PM   #1
chartz is offline chartz  France
Default CD104 reads CDRs but not CDs [solved]
Hello,
Well the title says it all.
To see what was done and thought so far, please start from here:
Philips CD104 tweaks
Thanks for your ideas!
Old 19th May 2013, 08:20 AM   #2
Hi!
A though one eh.
Perhaps somebody has the phone number of the Dutch engineer who designed the machine (-;
Old 19th May 2013, 07:39 PM   #3
PlasticIsGood's Avatar
I've just measured my own CD104b whilst playing:
CD/CDR eye pattern = 1Vpp/0.7Vpp, pin1 ic6212 = -4V/-5.5V
Yours is ?/1Vpp, 0.25?/-7
Are you sure your CDR eye pattern is 1Vpp, not 0.5Vpp
I note adjustments section of the manual gives pin1 as -4 +/- 2V
Old 19th May 2013, 07:56 PM   #4
Yes I'm sure.
Now I can't play CDRs! Yesterday I could (even from cold) and today...
What has changed? The radial motor never moves again, it just sticks to the motor spindle as soon as I power up.
In loop A I still measure the same voltages though.
I've ordered a TCA240, we'll see.
Old 20th May 2013, 04:18 PM   #5
Right then.
I have re-checked, I've got no AC signal at pins 12 and 13 of TCA240 (service loop A), so nothing either (just noise) at pin 8 of 6215 op-amp.
The real question is: what has it worked with CDRs until yesterday? Is it possible that one branch of the TCA still worked and that it finally gave up the ghost?
More of which when it is replaced, I can't wait.
Old 20th May 2013, 04:42 PM   #6
Mooly's Avatar
I admire your determination with this although I still feel the problem will come down to to the RAFOC.
What do Philips call the "focus OK" signal. Have you checked to see if there is any change on that line as the RAFOC does a focus search (with a disc present of course)
Old 20th May 2013, 05:24 PM   #7
I think that the tracking loop doesn't work because the transistors in the TCA are open circuit.
Radial error 1 and 2 signals (the difference is the final tracking error signal) can't find their way to the radial motor.
The error signals from the photodiodes are present and conform.
Old 20th May 2013, 05:31 PM   #8
Mooly's Avatar
Have you scoped and measured voltages on the TCA. Any problems related to one of the six transistors should show in measurement.
Old 20th May 2013, 05:34 PM   #9
Yes I have. Everything comes in nicely but nothing gets out!
Test points 24 and 25 show correct values, but nothing gets out at points 27 and 28, both signals going to the LM324 integrator.
Old 20th May 2013, 05:44 PM   #10
Mooly's Avatar
That doesn't necessarily mean its faulty unfortunately. All the evidence is in the voltage and/or dynamic signals present (as viewed on a scope) on those transistors and whatever is present, (whether right or wrong) should enable a good judgement of whether the transistors are functioning correctly.
What's on your bookshelf -- must reads jackinnj Everything Else 24 8th March 2017 04:40 AM
problems playing last tracks on CDRs? thetube0a3 Digital Source 4 16th March 2012 04:39 AM
Burning CDRs trwh Everything Else 9 27th July 2004 05:58 PM
Problems reading CDRs on NEC602 meat Digital Source 3 25th February 2004 08:52 PM
Marantz CD17 reads CDr ? junoman23 Digital Source 4 15th February 2004 10:42 PM
Copyright 1999-2017 diyAudio
