Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th May 2013, 04:23 AM   #1
Roushon is offline Roushon  India
Default CD-player: peculiar problem with the laser mechanism...
Day1: the player was stopping in between for couple of
seconds and then continued flawlessly...after an hour or
so it stopped completely saying `Error'. Thereafter it was
not accepting any disc saying `No Disc'.
Day2: I cleaned the tray, found some sand particle. It
started working again flawlessly....in the evening same
problem as Day1.
Day3: Opened the top. Checked cables, reversed some
cable suspecting loose connection...it started working....
Day4: The two second gap problem again resurfaced. So,
greased the mechanism by silicon grease thinking it was
not sliding well. Left it to play for several hours. Problem
came back after about 4 hours and completely stopped
working (like Day1) for two days.
Yesterday: (Did not do anything) It started working again
but with the two second gap problem...
It is puzzling!
Came to know this problem is common with this brand
(Marantz) of cd-player. I played it for all total 69hrs since
its purchase. I would like to solve it instead of changing
Roushon
S. Roushon
Old 7th May 2013, 04:38 AM   #2
Default Inside view!
The inside view of the player.
S. Roushon
Old 7th May 2013, 12:43 PM   #3
Any suggestion or hint about where to look at next....thanks!
Roushon.
S. Roushon
Old 9th May 2013, 06:32 AM   #4
Thought it will also have a peculiar solution! But, I had to go
to the straight forward way, replace the laser mechanism.
Thanks for the silence...may be I did not present the
problem well....
Roushon
S. Roushon
Old 11th May 2013, 05:26 PM   #5
I received the laser mechanism today. Before the replacement I played it and
the same problem was there (two seconds pauses). So, replaced the mechanism with the new one, it says `No disc'. Then read in this forum that I have to remove some solder blob, so I checked and removed the blob. But the same `No disc', in fact the lens aparatus is not even sliding. Tried for a long time then frustrated, put back the older lens, `No disc' came as reply, now it is not even playing although it did an hour back before I removed it.
Some help please before I run to the service center, which I am very much not interested in doing.
Roushon
S. Roushon
Old 12th May 2013, 02:57 AM   #6
Any suggestion or hint regarding where to look at. Would it be the capacitors in the main board?
Roushon
S. Roushon
Old 12th May 2013, 05:21 AM   #7
I am talking to myself...sometimes that also helps! Finally the old mechanism
came alive with whatever problem it had ( two minutes pauses). But the new
one trying to read TOC, disc rotating, but finally giving error message. All the
cable connections seem OK.
This is the second time I got into trouble after purchasing part from India,
although it was a genuine Marantz service center...definitely this is the last
time...huh!
Roushon.
S. Roushon
Old 14th May 2013, 04:38 AM   #8
Default Caution!
This is to caution you regarding the Marantz Service
center in Mumbai, MZ Audio distribution, Bandra. The
laser assembly they sold me is horribly bad. One motor is
dead and the laser circuitry is also wrong. Most likely
some used product was sold to me. Now they want me to
take the cd player to them so that they can check
themselves. I am afraid to do that suspecting they will
play some dirty trick with the existing good parts in my
player. Just wasted a non-trivial amount of money... I feel
like kicking myself to take this decision to try NOT TO
IMPORT the part directly from Marantz USA.
Roushon.
S. Roushon
Old 14th May 2013, 07:24 PM   #9
You might need grease on the bar on which the laser moves.
Usually, when I have to replace a transport, I buy a few on ebay to be sure that one will work.
Good luck with your cd player.
Philips CD-104 CD Player with All-Metal CDM-1 Laser Assembly dtm1962 Swap Meet 6 28th March 2013 09:14 PM
audiolab 8000 cd player mechanism spy1066 Digital Source 10 18th June 2011 11:55 AM
CD player with distortion. laser? grahamfocal Digital Source 289 13th December 2010 05:50 PM
Pure CD Player and DVD Transport Mechanism inside - what about this ?? tiefbassuebertr Digital Source 2 23rd February 2010 08:36 PM
CD player laser test jig Fantastic Digital Source 1 25th March 2003 04:45 PM
Copyright ©1999-2013 diyAudio
