Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sony CDP-101 spindle motor
Old 7th May 2013, 05:57 PM   #31
Mooly's Avatar
I can't make the package type out from the scanned manual. I take it that it is an SMD (surface mount) package.
Old 7th May 2013, 06:23 PM   #32
hifi_sk is offline hifi_sk
yes it seems to be SMD (from 1982). some pictures:
Old 7th May 2013, 06:29 PM   #33
Mooly's Avatar
Easy... once you have a bit of experience
Use solder braid to remove most of the solder first and then jewellers screwdriver to gently lift each leg as it is heated with the iron.
Its a bit different to this but you get the idea,
http://www.diyaudio.com/forums/parts...sed-tools.html
Old 7th May 2013, 07:15 PM   #34
nice manual, looks easy. well, I will try it. unfortunately no time for this yet, but I must to do it. nothing to loose :-)
thank you
Old 7th June 2013, 07:16 PM   #35
hello, I am back again.
IC-503 changed and it helps not. the spindle motor is still spinning
Old 9th June 2013, 05:24 PM   #36
Mooly's Avatar
Sorry, not ignoring your post I'd have to study the circuit again... as nothing obvious came to mind.
Old 9th June 2013, 06:50 PM   #37
hello,
you do not have to apologize. today I have placed the "wrong" IC-503 to the other board where I get the "good" IC-503 and this board is working good (spindle motor is not spinning without reason) so I am sure the IC-503 was OK.
Old 27th June 2013, 03:18 PM   #38
chartz is offline chartz  France
Is the little red connector in the middle plugged?
Old 27th June 2013, 06:04 PM   #39
yes it is, you probably mean symetric voltage connector.
Old 27th June 2013, 09:24 PM   #40
Since with it unplugged the motor will go full throttle at power-up, I was wondering...
Sony CDP-101 spindle motorHide this!Advertise here!
Sony CDP-101 digital output? Help needed!!! chrisbp Digital Source 3 16th May 2014 05:43 PM
Sony CDP-101 transport problem argonrepublic Digital Source 0 24th July 2011 06:31 PM
Where can find SONY CDP-101 Service Manual olaychang Digital Source 6 5th May 2008 07:49 PM
Sony CDP-101 Tray Problem idealist Digital Source 3 11th August 2007 02:37 PM
Sony CDP 101 Zero One Digital Source 2 28th April 2006 09:06 AM
