| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Great link, 00940!
Tnx
"I`m not the messiah!" |
#12 |
So after looking my *** off, I found that rs-components, has almost al the panasonic fc series.
I`m still not confident in the de ( ?) coupling caps 0.1 uF, would mkp wima`s be nice for that? And I can`t seem to find 4700uf and 15000uf 35 or better caps, which comes close to the pana`s. btw, nichicon any good? anyone got more tips? Else I will see if I can get my hands on bc components. God, you must get annoyed by all these questions... - sorry-
#13 |
Sanyo MV-AX series are worth looking at. Low impedance 105C.
I used them in a switching regulator for pentium 2 processsor core voltage which called for <100mV ripple at 30A/us. Switching frequency 300kHz. This Sanyo was one of the few that really worked. Only OSCON was better. |
#14 |
In digital part Elna RJH is also worth a try, in analog supplies Pana FC is a bit better for my taste.
#15 |
Do those caps from sanyo come in large capacities? Or is that for the 0.1uf nice? Are the oscons, in the same leaque as the FC panasonics?
I found a nichicon LLQ series 4700uf but i don`t know if the esr on that one is nice, any guidelines on esr ratings? I finaly found a rubycon 15000uf usp series, but as with the nichicon, I don`t really know if this is any good, I don`t see "low esr" mentioned on the data sheets. Since I cannot completely interpet the esr rating, I rather hear from u if it MIGHT me nice. Guess I will read the "picking caps" page again. If I use one of these, while al the other caps are panasonic fc, will that be redundant, because I will put in 1 "bad" cap, or will it not deteriote the ps, as a whole?
#16 |
Sanyo MV-AX are frpm 1uF and up electrolytics.
I'm using 1500uF 50V Sanyo's in my 5 channel gainclone. I can hardly see any noise at 50mV/cm on my scope. |
#17 | |
diyAudio Moderator Emeritus
It's only audio |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| Worth doing cheap "thermal protection fuses" in hot amps? | cfcubed | Pass Labs | 4 | 15th June 2008 02:27 AM |
| Sonus Faber 6.5" woofers and cheap 3" fullrange and misc. | Jimmy154 | Swap Meet | 10 | 26th December 2007 04:20 AM |
| The "Really simple and cheap speaker designs for the newbie!" thread. | Spasticteapot | Multi-Way | 5 | 19th March 2006 04:16 AM |
| cheap 6" or 8" woofer to make great bass for a standard cab pick up | zuki | Subwoofers | 12 | 15th February 2005 07:54 AM |
| Page generated in 0.09175 seconds (73.85% PHP - 26.15% MySQL) with 10 queries |
