Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
How to make correct adjustment of CDM4
Old 29th November 2003, 07:25 PM   #1
Tubeee is offline Tubeee
Default How to make correct adjustment of CDM4
Hi all pro,
There are two vars(potmeter) combo with CDM-4 laser pickup system (on the pcb beneath the CDM-4), 4K7 and 22K. As I know these VARs are for the adjustment of laserdiode output and focus.
Questions are:
How to make precisely adjustment. Does anyone has related service manual?
If I change a new CDM-4, do I need to re-adjust these var to a correct value? (I think my CDM4/19 is dying)
need your kindly help....
Old 30th November 2003, 01:17 AM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
How to make correct adjustment of CDM4 How to make correct adjustment of CDM4
Cool What a hardcore diy'er do on a rainy saturday-night:
Having nothing better to do(?), I took the old laser out of my CD-16 (CMD4-d36) and swapped the internals(laser) from a new CDM4.19.
Only the platter-motor differs (exept the metal...)
And everything works well, playing now...
Arne K
Don't believe everything you think...
Old 30th November 2003, 03:47 AM   #3
Hello Rudolf Broertjes,
I just search your previous post:
http://www.diyaudio.com/forums/showt...456#post120456
I think that's what I want to know now:
I have the adjustement procedure for tracking & focus with the two test points (50mV and 400mV).
Where is these two test points: (or which registors?)
50mV is for tracking (laserdiode output)
400mV is for focus.
Is this done by using amp-volt meter to measure specific registor and check the amp cross it?
thanks
Old 20th November 2004, 11:15 AM   #4
zygibajt is offline zygibajt  Poland
Any one knows where the test points for this 50mA and 400mA are?
I got the CD-player where someone turned two trimming pots all the way up!
Bartek
Old 20th November 2004, 12:11 PM   #5
DIY !
Cobra2's Avatar
Default Adjustments
I guess it will be on different location in different players...
What make & model?
Arne K
Old 20th November 2004, 12:44 PM   #6
There are always 22K and 4,7K pots and all the chips are usually the same.
The model in question is Marantz CD 883 but I have a couple of other ,diffrent machines and with CDM4/19 laser/drive it's always the same.
In fact this Marantz CD 883 is identical inside to the Marantz CD 65MKII ,just the same main board.
I have similar procedure for CDM 2/10.It goes ..."measure acros this resistor near that chip...and so on"
I need similar procedure for CDM 4/19
Bartek
Old 20th November 2004, 03:14 PM   #7
Bricolo is offline Bricolo  France
Bricolo's Avatar
Is the procedure the same for all CDM4 based machines?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 20th November 2004, 04:07 PM   #8
I suppose it is.Chips and topologies are the same.
If any one knows it please share it with me.
Bartek
Old 22nd November 2004, 09:13 AM   #9
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Here you are
Designators can/will differ between several versions.
Just look for similar valued resistors on the pcb;
Many old Philips players can be measured near top left of transport.
Rudolf Broertjes
Old 22nd November 2004, 12:44 PM   #10
Many thanks Rudolf
How to make correct adjustment of CDM4Hide this!Advertise here!
need help with CDM4 laser adjustment vubkevin Digital Source 2 23rd August 2009 11:26 PM
CDM1, or CDM4 pro, or CDM4/21 jovan Digital Source 7 27th February 2008 02:33 AM
Need help to make a correct 83 (merc.vapor.rect) SS replacement. bembel Tubes / Valves 5 20th February 2007 05:30 PM
Repairing CDM4/19 (with CDM4/31???) Shaun Digital Source 4 1st August 2003 01:29 PM
Copyright ©1999-2017 diyAudio
