| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi All
Does anyone have a copy of the schematic of the audio section of the Sony DVPS 7700 dvd player? Many thanks for any help. Smiffy. |
#2 |
I am expecting service manual for this player any day now. Let me know what exactly you need.
#3 |
Hi Wanderer
Do you happen to have S7000's service manual, too? Did you directly oder the manual from Sony? Thanks. -finney |
#4 |
Hi Wanderer
Just need a scan of the schematic for the audio board(which I think is marked AU218)and if poss confirmation that the master clock is 45.1584MHz.Any help would be greatly appreciated Smiffy |
#5 | ||
#6 |
Hi Wanderer
Just the 2 Audio bits would be fine and if poss the Audio power supply. Scan would be best if thats ok with you.Thanks you so much for the help.I would like to tweak it up a bit so that its as good as my tweaked 7000 with a bit of luck. Ta Smiffy |
#7 | |
#8 |
aentity@btinternet.com
Wanderer, Many thanks,will let you know when they arrive.Could you also check the schematic and see if the master clock is 45.1584MHz Smiffy |
#9 |
Smiffy,
I got your address, you can remove it now. Will fax everything tonight (GMT-5), will verify frequency also. |
#10 |
Hi Smiffy
Would you mind sharing your tweak of s7000 with us? Have you done anything to the digi out circuit? Warderer, thank you for the reply. Looks like I will have to order the service manual myself this time. -finney |
| Sony MHC-RV22 CD section problem | sukhbinder | Digital Source | 8 | 23rd July 2008 05:40 PM |
| Cambridge Audio A1 power amp section schematic? | Spev | Solid State | 2 | 10th July 2007 09:57 PM |
| Technics SU-7700 | rhymeswthorange | Solid State | 18 | 16th April 2005 12:49 AM |
| schmatic for the audio section of A Fisher K-14 chassis | battradio | Tubes / Valves | 1 | 1st January 2004 11:57 PM |
| Master clock freq for Sony 7700? | Smiffy | Digital Source | 2 | 5th December 2003 01:58 PM |
| Page generated in 0.10959 seconds (78.12% PHP - 21.88% MySQL) with 10 queries |
