Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
denon dvd-3910 service manual ?
Old 10th April 2013, 02:32 PM   #21
dazzz is offline dazzz  Israel
This circuit stereo
Look at the FL FR C channel
They go to another card
Old 10th April 2013, 02:38 PM   #22
This specification of the DVD
The main system unit also contains the audio circuitry for the centre, subwoofer
and surround channels, based on two Texas Instruments/Burr Brown PCM1796 chips (each chip operating in stereo or dual channel mode), eight 2068D op amp chips plus an assortment of fairly high quality capacitors. I also noticed two oscillators, operating at 24.576MHz and 18.75MHz.
On top of this board, completely enclosed by metal shielding to protect the audio circuits, is a separate board for the FireWire interface. The design is based on a Bridgeco L5A9625 processor and is separately clocked using 22.579MHz and 24.576MHz oscillators.
The third board stacked topmost is a dedicated board for the audio front left/right channels. Here we find another two PCM1796 plus no less than ten 2068D op amps and accompanying capacitors. The Denon literature implies that one PCM1796 is used for the dedicated stereo left/right outputs (containing a downmixed signal for multi-channel sources) and the other is used for the front left/right channels forming part of the analogue 5.1 outputs.
In 3910 my brother has a total of 18 2068D OPAMP
on different audio circuit 10 on Sketch 14 and 8 mor on Sketch 7
Old 10th April 2013, 02:39 PM   #23
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Well then It must be IC307-310 you should change.
Regards Åke
Old 10th April 2013, 02:54 PM   #24
SL. SR .C OPAMPS -Sketch 7
IC223 IC224 IC227 IC228
IC225 IC226 IC229 IC230
FL FR CHANEL OPAMPS- Sketch14
IC301.IC302.IC303.IC304.IC305.
IC306.IC307.IC308.IC309.IC310
Old 10th April 2013, 03:13 PM   #25
Ryssen's Avatar
Well you can change all of them,but If I where to only use the FL,FR output I would only change the IC307-310.
Regards Åke
Old 12th April 2013, 04:05 PM   #26
Today I opened the My DVD 3910
And I took with my camera CANON 5D
Few photos Something strange -the op amps
Instead 2068D Write on them 15218/5808
Old 12th April 2013, 04:39 PM   #27
Ryssen's Avatar
http://www.google.se/url?sa=t&rct=j&...C4GjKtF_3E4Otg
Regards Åke
Old 12th April 2013, 04:57 PM   #28
Strange that SERVICE MANUAL
Write supposed to be there 2068D
Can I change them DA8620 ?
Old 12th April 2013, 06:19 PM   #29
Ryssen's Avatar
DA8620 is some kind of displaydriver,that one you can´t use..
AD8620 on the other hand u can use.
Regards Åke
Old 12th April 2013, 06:33 PM   #30
bro what is the best dual op amp you recomend my
I'm really confused wide selection ???
And today I opened device are very small
You recommend using hot air gun ?
Surface Mount IC - YouTube
denon dvd-3910 service manual ?Hide this!Advertise here!
Denon DVD-2910 service manual? MrMajestic Digital Source 30 3rd January 2013 04:51 AM
Denon DVD-3930 Service Manual required Fidelity Audio Digital Source 0 29th August 2008 08:43 AM
Denon DVD-3910 service manual/schematics andrei Digital Source 16 25th July 2008 08:57 PM
