denon dvd-3910 service manual ? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th April 2013, 10:45 AM   #11
dazzz is offline dazzz  Israel
I understood by drawing IC311 -1796 BURR BRAWN
IC301 IC302 IC303 IC304 IC305 IC306
ind the secand IC312 -1796 BURR BRAWN
IC307 IC308 IC309 IC310
So how has 8 ????
In your opinion
what the ic i need to change from 301 to 310 ?
Old 10th April 2013, 11:52 AM   #12
dvd denon 3910 stereo audio unit
Old 10th April 2013, 11:55 AM   #13
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
So how has 8 ????
In your opinion
Is for the Front speakers that u use for 2 channel stereo.
So its 4 opams (8 single opamps)
Regards Åke
Old 10th April 2013, 12:05 PM   #14
What about the OPAMPS
Do you think they not need to replace ?
(I know that 2068D is a dual OPAMPS )
Old 10th April 2013, 12:16 PM   #15
Ryssen's Avatar
They are for the rear channels,I don´t know if you are going to use them,then maybe you can change them.it´s up to you.
Regards Åke
Old 10th April 2013, 12:29 PM   #16
Are you sure I know all the circuit from 301 to 310 only addresses stereo
There are still 8 other opamps in defrent circuit
The main system unit also contains the audio circuitry for the centre, subwoofer and surround channels, based on two Texas Instruments/Burr Brown PCM1796 chips (each chip operating in stereo or dual channel mode), eight 2068D op amp chips plus an assortment of fairly high quality capacitors. I also noticed two oscillators, operating at 24.576MHz and 18.75MHz.
On top of this board, completely enclosed by metal shielding to protect the audio circuits, is a separate board for the FireWire interface. The design is based on a Bridgeco L5A9625 processor and is separately clocked using 22.579MHz and 24.576MHz oscillators.
The third board stacked topmost is a dedicated board for the audio front left/right channels. Here we find another two PCM1796 plus no less than ten 2068D op amps and accompanying capacitors. The Denon literature implies that one PCM1796 is used for the dedicated stereo left/right outputs (containing a downmixed signal for multi-channel sources) and the other is used for the front left/right channels forming part of the analogue 5.1 outputs.
Old 10th April 2013, 01:09 PM   #17
the circuit for rear channels und canter
diagram 7 on the service manual
2 burr brawn 1796( IC221-IC222) and 8 op amps 2068d
IC223 IC224 IC227 IC228
IC225 IC226 IC229 IC230
Old 10th April 2013, 02:06 PM   #18
Ryssen's Avatar
I would think where it says FL and FR is the stereo output,the other one says MIX.(the one above in the schema)
I have not changed these opamps on my DVD3910,so I am not absolutely sure.
Regards Åke
Old 10th April 2013, 02:21 PM   #19
Dude you need to change all 10
All belong to the stereo channel
the FL FR C ar on
another bord
8 opamps
Look at the photo
Old 10th April 2013, 02:31 PM   #20
Ryssen's Avatar
If you follow the trace from the FL.FR RCA kontakt,then you will see where it is.
Regards Åke
Denon DVD-2910 service manual? MrMajestic Digital Source 30 3rd January 2013 04:51 AM
Denon DVD-3930 Service Manual required Fidelity Audio Digital Source 0 29th August 2008 08:43 AM
Denon DVD-3910 service manual/schematics andrei Digital Source 16 25th July 2008 08:57 PM
Copyright ©1999-2017 diyAudio
