Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st December 2003, 02:19 PM   #11
Default Re: Were getting closer....
Originally posted by Bryan
Guido,
What are the "best" available replacement's, and where does one source them? Is there ample support literature to guide one throught the implementation of the new clock?
Lets deal with the opamps later.....
I assume the above are your favorites.
How much money do clock replacements cost, and how long of a project is it to finish, 1 hour, 1 day, few days???
Also, does the new power supply come from tapping into an existing supply in the CDP, or is it built/added alongside during the clock swap? I assume this PS needs to be very clean?
Always learning more!!!
Thanks,
Bryan
Bryan,
I propose you do a search on DIYaudio. There are many clocks available:
Trichord
Audiocom
Elso Kwak
LCaudio
TENTlabs
and probably more that I am not aware of
I haven't been able to compare them all soundwise, but by measurement I found differences. Pricewise they differ a lot, as well as the DIY level of what is delivered and required to mount them.
Power supply in general should be very clean, and adding seperate transformer / rectifier is recomended.
As I am one of the manufacturers, I will not comment any more, but I am sure other members may be of help.
Guido Tent
www.Tentlabs.com
Old 1st December 2003, 02:24 PM   #12
Bryan is offline Bryan  United States
Guido,
Understood
I'll do a detailed search, and ask around for feedback.
I appreciate you getting me started.
If anyone else wants to add any more input, please do so.
Thanks All,
Bryan
Dont take life too seriously, you will never get out alive!
Old 1st December 2003, 03:37 PM   #13
Banned
Default Re: Re: Ok... Lets focus on the NAD S500
Originally posted by Guido Tent
The timing of taking subsequent samples however depends on the short term stability of the clock. When converting from digital back to analog, a timing error automatically leads to an amplitude error.
Well said. But the timing error and subsequent amplitude error is only significant if the amplitude of the digital sample can be reconstructed to exactly equal the amplitude of the original analog signal. It cannot.
First, the digital sampling, with a finite number of bits, cannot accurately represent an analog signal. There will be a sampling error in the range of +/- ½ LSB.
Second, most modern-day digital audio production adds dither to the signal, which amounts to another ½ to 1 LSB of random noise.
Third, DACs are rarely linear down to the LSB.
Fourth, the typical DAC settling time is usually far greater than any XO jitter.
Fifth, given the inherent jitter in any digital circuit, especially one implemented in slow HC logic I fail to see how a little XO jitter can be a bad thing.
In fact, the effects of jitter are really no different than the effects of dither; they both introduce a small random error to the reconstructed audio signal.
Old 1st December 2003, 03:52 PM   #14
Default Re: Re: Re: Ok... Lets focus on the NAD S500
Hi
My ears and measurements tell me that clock oscillator jitter still counts, at least improving the average oscillator in a CDP improves sound in my ears.
I am not refering to the lsb only, modern DAC are linear to and beyond 16 bits, which is on the disc, I do not expect more to come of.
Settling time is rather constant, though depends on (local) power supply variations, so I do not see the correlation with jitter you include here.
Oh, and the well know everywhere to find 121 ps jitter requirement is not valid. I dd some simple tests using a VCXO and well defined signals on the control port to show that.
best regards
Guido Tent
www.Tentlabs.com
Threshold Stasis S500 Series II amandarae Pass Labs 9 21st November 2009 05:39 PM
D/a Nad S500 !!! ANADIGIT Swap Meet 1 13th August 2009 04:58 AM
Soundstream DAC1 schematic Zen Mod Digital Source 0 23rd March 2008 05:31 PM
An Dac1 drobert Digital Source 0 18th September 2006 01:13 PM
Page generated in 0.08783 seconds (77.48% PHP - 22.52% MySQL) with 10 queries
