| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#61 |
Hi, Mikee12345 -
As a consumer storage format, in general I think 24 bit DVD audio with at least 88ks/s is at least competitive with most analog media on its stronger points, and ideally 32 bit dynamic range for professional applications, so that a few bits of lost resolution due to processing or non-optimized recording level won't automatically destroy SQ. A very robust 'perceptually encoded' format using the CD data rate should also be able to easily meet that consumer standard. Of course, there's a 20 year accumulation of shitty 16 bit 44.1 & 48 ks/s professional equipment that needs to be disposed of somehow and the average quality of audio a/d's & d/a's needs to improve several notches to fully take advantage of a 24 bit or better storage resolution. |
#62 |
As i wrote some posts before the decoding is from some interest also.
I always used the lame integrated or the Nero fhg decoder because i never was convinsed by the better performance of the Mad decoder. These days i tried some and found "foobar2000" with dithered diskwriter-plugin really a step in front! I was surprised myself. With the headphones on the PC it is hard to tell which sounds better but for sure different. foobar sounds brighter here in a way. When listening on my system the difference is much more existing in a moment. The dithered, decoded mp3 really is much clearer and more detailed. Any other findings regarding this are welcome.
If time permits - stuff some parsley in your ears and listen how it grows! |
#63 |
Foobar2000 is the best quality player around for most compressed formats at the moment.
Anyone not using it already should give it a go. |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| How to get rid of "CKK" Sound on "turn off" | riotubes | Parts | 0 | 25th November 2006 03:50 PM |
| FE127E enclosure tweaks to improve "honky" sound | arjscott | Full Range | 13 | 1st August 2006 06:06 PM |
| Can anyone suggest the "best" 300B SE sound quality schematic for a beginner like me? | calico88 | Tubes / Valves | 42 | 18th July 2006 02:33 PM |
| Thiele-Small R_ms (mechanical losses) vs. "precise" sound? | capslock | Multi-Way | 7 | 16th September 2002 09:32 AM |
| Page generated in 0.29780 seconds (21.80% PHP - 78.20% MySQL) with 11 queries |
