Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
PCM1704 NOS Strange Clipping
Old 28th March 2013, 12:37 AM   #1
LuisMCP is offline LuisMCP  Spain
LuisMCP's Avatar
Default PCM1704 NOS Strange Clipping
The DAC seems to work properly in the beginning a nice sinusoidal can be saw in scope, but 1 minute after, a clipping in negative zone is slowly growing up to a certain level.
Both channels L and R are affected, two different I/V converters was tried and same results was obtained.
Pin 17 (SERVO_DC) has different voltage in both chips. One at 0,00V and another at -2,40 volts.
Some idea what the matter?
Old 28th March 2013, 02:38 AM   #2
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Are pins 11 and 20 at + and - 5vdc constant? Maybe one of your 5v regulators are on the fritz when it warms up.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 28th March 2013, 12:56 PM   #3
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
I agree with George, the first thing to do is check whether the power supply rails are stable and without significant ripple voltage, especially, the negative rail.
Old 28th March 2013, 02:10 PM   #4
LuisMCP's Avatar
I'm using a Twisted Pear Dual Power Supply (LCBPS).
I have checked +/-5V correctly, and I have change LM337 and electrolitics caps and all remains the same.
1-2 minutes of clean signal, then clipping in negative sinusoidal. Power off the DAC and exactly the same thing ever and ever.
Both channels fails equally, I have interchanged the PCM1704 (they are socketed to DIP 20 adapter), I have put only one PCM1704 in L, then in R channel, and allways get the same results.
I don't have another PSU for testing right now, but probably this afternoon I would get one.
Old 28th March 2013, 03:50 PM   #5
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Have you checked with scope?
Old 28th March 2013, 05:37 PM   #6
LuisMCP's Avatar
Yes, as I have mentioned it in my fist post.
Old 28th March 2013, 06:03 PM   #7
Luis could you post a pic and schematic used?
Old 28th March 2013, 06:52 PM   #8
s3tup is offline s3tup
s3tup's Avatar
Drop the I/V, put some 20ohm resistor to ground instead, check with scope. This way we eliminate everything but the DAC and it's digital side.
If the clipping is still there, and the supplies are absolutly fine then... well, i hope you wont see that clipping thing again
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 28th March 2013, 07:03 PM   #9
LuisMCP's Avatar
interesting. I will try this
A question... I/V I use is a common opamp v to i converter, and of course, inverts the signal. Then, If I see negative side clipped in scope and i/v inverts, DAC output is with positive side clipped, and the problem would be in positive rail of psu, not the negative rail.
Old 28th March 2013, 07:10 PM   #10
s3tup's Avatar
Opamp's PS may fail too, so it won't supply the current required = give high virtual impedance = clip. What is the resistor value in opamp's feedback?
Anyway, lets check the DAC first
PCM1704 NOS Strange ClippingHide this!Advertise here!
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board iancanada Digital Line Level 910 21st January 2018 01:08 PM
High-end NOS DAC Kit with PCM1704 up to 24bit/192KHz Eric Juaneda Vendor's Bazaar 6 24th September 2010 06:47 PM
6sn7 NOS tubes with strange white sth on pins mad_z Tubes / Valves 7 21st October 2003 12:42 AM
