| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a Polk RMDS-1 Preamp/processor, a dvd, DSS digital and a game console... All with Digital audio. The RMDS-1 has a place to plug in an optical cable for the DSS, a digital location for the DVD and a digital location for a 12" laser disc. The manual says not to use the 12" LD input for anything but a dolby digital RF signal from a LD... Thats fine, but how the heck am I supposed to utilitze the digital audio for my game console if I only have two digital inputs? Is it ok to use a splitter ??? and which would be bettter to split, the optical from the DSS or the cable from the DVD? Thanks for any help you guys can offer! |
#2 |
Sorry, you can't use a splitter. The digital signals have timing marks that would get confused. Unless you were willing to turn off the component not in use.
You could probably get away with using a good quality DPDT switch, a 75ohm resistor and 3 RCA jacks in a small project box. Wire it up so that the selected input switches to the output, and the unselected input goes to ground through the 75ohm resistor. Reverse in the other switch position. If you need a sketch I can try to do one later. Commercial offerings I am aware of: MSB makes the "Digital Director." MSB Partsexpress has a "Digital Optical Selector Switch", part number 180-980 for less than $20. Partsexpress Radio Design Labs has an "RU-SPX4 Digital Audio Selector." RU-SPX4 --David |
#3 |
Banned
Hi snootleather,
You could use a multiplexer IC after bringing the signals to logic level. You could also use comparators at the inputs like AD8561 and use the LATCH function to enable the desired comparator to be active. |
| please help me on digital decoder/splitter | JinMTVT | Digital Source | 1 | 4th April 2008 02:35 AM |
| Adding Digital Inputs ?! | Blue_Max | Digital Source | 3 | 25th January 2005 08:12 PM |
| Digital Optical Cable Splitter | midwestaudioguy | Digital Source | 0 | 31st August 2003 07:57 PM |
| Page generated in 0.06877 seconds (72.04% PHP - 27.96% MySQL) with 10 queries |
