Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th November 2003, 12:59 PM   #11
Default jitter
Also, there may be some jitter concerns. I am using a Phillips CDM12 unit in a wooden (unshielded) box. It is very noisy in RFI. Due to layout the digital cable actually crosses the AC power line and comes close to the power tranny.
Old 25th November 2003, 01:20 PM   #12
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Ah yes...I suspect that could be the real reason for your "problems"...
Does the CDM12 have I2S?
Bas
Old 25th November 2003, 01:34 PM   #13
Default I2S
Yes it does, combining DAC and transport is a future project, and also isolating the power supply (probably more batteries).
On that theme, does anyone have any criticisms about putting transport, DAC and perhaps amplifier in one chassis? I was wondering particularly about vibration from the transport motors etc.
Old 25th November 2003, 01:39 PM   #14
Andypairo's Avatar
In a discussion with Elso Kwak he mentioned that he had bad results putting a TDA1543 based dac inside the chassis of the CD player, probably due to RFI.
Try shielding it or putting it outside.
Cheers
Andrea
TDA1543/CS8414 Problems... john65b Digital Source 10 6th October 2006 02:19 PM
Bearing problems...need some advice Capt Zach Analogue Source 14 16th August 2006 05:00 PM
TDA1543 problems lasso Digital Source 55 24th March 2006 04:42 PM
Advice on part selection on USB PCM2706 TDA1543 DAC swak Digital Source 0 31st October 2005 11:04 PM
Page generated in 0.07647 seconds (66.37% PHP - 33.63% MySQL) with 10 queries
