| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm looking for a replacement gear for a Marantz CD 52. My dear son forced the tray and you can see the result for yourselves. Any idea what's the part number, or where could I get a replacmet (not for the son!). Thanks, Amos |
#2 |
diyAudio Moderator Emeritus
If you would have used the Search function, you would have found this:
tray gear for CD-M4 and CD-M9
It's only audio |
#3 |
Strangely enough, I did use the search option.
I tend to look closely at what I see before I pass judgment: The wheel on the left, has a cylinder at the base of the cog, but mine does not (so I'm probably not looking for a CD M9 mechanism). The one on the right is too brightly photographed to see if it's the one I'm looking for (so I don't know if I'm looking for the other type CD M4, or for something different). So... I posted a question. Do you know what's is the part number I'm looking for? |
#4 |
did you ever get that tray loading wheel for your CD52 in the end ? I have the same problem with my CD52 and I was wondering if you (or anyone) have a part number for this item ? Many Thanks Jonathan |
#5 |
here is a picture of the offending part...
I would be very greatful for help on this ![]() Jonathan |
#6 |
That part looks similar (splines all the way to the disc) to the one in my CD624 (CDM4/19). The part no. in the 624 service manual is: 4822 466 61587.
If you contact Philips, they should be able to describe the shape of the part to you before you order it. you might as well get a new belt at the same time. The part no. is: 4822 358 10115.
Regards Fin |
#7 |
Thanks for the advice !
Cheers... Jonathan |
| Marantz...CD50...CD52...CD60.... | Lyra | Digital Source | 17 | 12th February 2009 11:27 AM |
| My DIY project with Marantz CD52 and Amp. Advice welcome | SE_ClassA | Solid State | 3 | 26th June 2006 05:18 AM |
| Help : Marantz CD52 HF signal to SAA7310 <1Vp-p | tbklbl | Digital Source | 2 | 5th January 2004 10:12 AM |
| Help for Marantz CD72 and CD52's I2S | deskmate88 | Digital Source | 7 | 14th July 2003 10:39 AM |
| Page generated in 0.13271 seconds (60.67% PHP - 39.33% MySQL) with 11 queries |
