Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Wadia 21 Dead laser or servo problems?
Old 7th February 2013, 11:38 AM   #31
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Originally Posted by Mooly View Post
The "virtual ground" thing is a bit weird on these. M52104 ? this is a 52103.
Couldn't find anything on that either...
But even that schematic you posted correctly shows Pin 1 as VC and Pin 6 as ground! and I do see in your schematic that the Pin 1 line goes to a VC test point. where as the VRDS-T1 (and hence Wadia 21) is not shown or as verified, connected that way! I really think this is a Teac factory mistake!
It's not about what you can BUY...It's about what you can BUILD!
Old 7th February 2013, 01:40 PM   #32
Mooly's Avatar
I doubt there's a factory error tbh.
In your diagram it doesn't actually say that pin 1 on P701 goes to Pin 1 on the KSS. It implies as much but doesn't quite go as far as showing that.
Old 7th February 2013, 01:48 PM   #33
Zero Cool's Avatar
I pinned it out, I took the dead laser apart and with a multimeter checked that Pin 1 really is connected as show and that Pins 5&6 are also as shown and the PCB's are labeled as to which is Pin 1 etc. So YES It is connected as shown!
But what I did find on a sony schematic for a cd player that also used the KSS-240A is that VCC is shown as +5, Gnd is gnd but VC is shown as +2.6v or almost have of VCC so maybe VC is not -5 but a half supply reference?? and if the T! is running off +/-10V Gnd would be half reference! But still every schematic i can find shows these lasers and pretty much all the KSS series to be running from +5v. without a datasheet it's hard to know but it's interesting.
Old 7th February 2013, 02:03 PM   #34
Mooly's Avatar
Have you actually measured the voltages for real to see what they are.
Old 7th February 2013, 02:35 PM   #35
Zero Cool's Avatar
Yup! All voltages are as labeled!
Old 7th February 2013, 05:57 PM   #36
Mooly's Avatar
You mean with 10 volts across the pickup. Very strange I agree but I think you have to take it as correct.
Wadia 21 Dead laser or servo problems?Hide this!Advertise here!
Dead Dead Laser Pickups - why not replacing the Diode only? Salar Digital Source 36 14th March 2017 06:21 AM
Wadia Drive 8 Laser unit Wim J Digital Source 12 10th June 2013 08:48 PM
Wadia 6 with tracking/focussing/problems RobertS61 Digital Source 2 19th February 2011 07:55 PM
Wadia 21 schematic wanted Alfetta87 Digital Line Level 11 11th March 2009 03:20 PM
Wadia 21 chipset Alfetta87 Digital Source 3 22nd November 2006 03:27 PM
Copyright ©1999-2017 diyAudio
