| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hey all...
I'd really appreciate some help. I'm looking for some really flexible, small diameter coax cable to be wound up on a 1.5" spool. I've been looking around at the 300 level RG types. I'm curious if there's any with a NON-solid core... a stranded center core type. Impedance will be customer dependant - 50 or 75 ohm... not sure yet. The reason I'm interested in the stranded core is for long-term durability from bending constantly to be wound up on a spool. Application is for a project at work that would really make things easier. I have always assumed that the cables on the probes from my Tektronix TDS2012 scope are coax... but they have no marking on them. They are a good place to start for flexibility. Any places or suggestions to start would be a big help. We will be ordering A LOT of this cable (many thousands of feet) on a regular basis, so please keep that in mind. Your help is appreciated - thanks to all!!
Tieftoener -- You're ears can sense a movement in air that causes your eardrum to move less than 1/10th of the diameter of a Hydrogen atom! Don't abuse the one of the most amazing organs your Creator gave you! |
#2 |
Digikey could get you some...I know the type your talking about
#3 |
diyAudio Moderator Emeritus
RG174 ( 50 Ohm ) or RG175 ( 75 Ohm ) ?? Both are flexible and 3 mm in diameter.
It's only audio |
| Flexible Cable | Kral57 | Everything Else | 0 | 10th September 2008 06:21 PM |
| My small BVR with 5 inch Coax | Circlomanen | Multi-Way | 11 | 17th August 2007 06:01 AM |
| flexible wire | johngalt47 | Parts | 5 | 10th January 2005 12:35 AM |
| Flexible plywood.... | jonz | Multi-Way | 4 | 5th June 2004 10:11 PM |
| Looking for flexible Heatshrink | Silver Stealth | Everything Else | 0 | 19th May 2002 12:06 PM |
| Page generated in 0.08286 seconds (74.70% PHP - 25.30% MySQL) with 10 queries |
