Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
SRC4192's are on the way... :)
Old 18th November 2003, 06:31 AM   #1
Tieftoener is offline Tieftoener  United States
Tieftoener's Avatar
Default SRC4192's are on the way... :)
I just got confirmation from TI that my SRC4192's are shipped and on the way to my door Woo hoo!!! Anybody got a preliminary design worked out yet???
Just wanted to give a heads up to those that were waiting on backorder also for their samples...
l8erg8er
Old 18th November 2003, 08:51 AM   #2
AD1865 is offline AD1865  China
Default I have tryed AD1896
IMHO, The AD1896 sounds smooth but no bass strength, and with no sensation, becaue the data is completly changed! It's garbage.So I don't think the SRC4192/3 can give us an better sound than without it, although its spec is very good.
Old 18th November 2003, 01:49 PM   #3
tiroth is offline tiroth  United States
I have some boards for AD1896/AD1853 that would work, but there is some kind of clicking in the left channel. Very annoying. I am wondering if is because I used very early stock AD1896, I know there have been some problems with those.
Old 19th November 2003, 12:07 AM   #4
Default my dac with ad1896 runs well
My DAC DIR1703+AD1896+AD1852 runs well,but the sound is
very "atony" and lack bass.Check the circuit diagram if some sets
wrong.
Old 19th November 2003, 12:14 AM   #5
Do you use slave-mode output?
Old 19th November 2003, 02:02 AM   #6
Default I didn't use slave-mode output
I only use 96KHz sample rate,the slave mode is hard to
use,and the THD of AD1853/2 in 192KHz is worse.
Old 19th November 2003, 01:27 PM   #7
Brian Brown is offline Brian Brown
Make sure that the /RESET timing is being correctly met. /RESET must be held low while the rest of the AD1896 powers up, or problems such as clicking may occur.
Brian.
Old 19th November 2003, 01:31 PM   #8
I haven't found the AD1896 to make any change in tonal balance. In my setup, the strength and general character of the bass is the same as without the AD1896.
Brian.
Old 19th November 2003, 02:01 PM   #9
Which D/A do you use? My DAC with AD1852 can easily been
heard that the bass have no wallop. Although I use AD811 as
buffer.
Old 19th November 2003, 02:16 PM   #10
I'll have to check ~RESET out Brian--thanks. First time anyone had heard of a similar problem!
I use a global reset, for DIR, ASRC, and DAC (from a reset generator). The PSU is stabilized by that point, but since DIR and ASRC are simultaneously reset the input clocks are not active when ~RESET goes high. Do you really think this could be the reason?
SRC4192's are on the way... :)Hide this!Advertise here!
SRC4192 Use... MWP Digital Source 33 26th April 2005 08:17 PM
What about SRC4192? Dear sirs foo Digital Source 0 19th December 2004 01:48 AM
AD1896 vs SRC4192 Marek Digital Source 4 8th November 2003 08:05 PM
New ASRC - TI SRC4192 tiroth Digital Source 1 27th August 2003 11:49 AM
Copyright ©1999-2017 diyAudio
