diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Pink Triangel Numeral burn Resistor ? (http://www.diyaudio.com/forums/digital-source/227379-pink-triangel-numeral-burn-resistor.html)
M-05 9th January 2013 10:01 AM
1 Attachment(s)
Hello :)
Hope there can be some help to get in here; I have a Pink Triangle Numeral cd player with a burn resistor R-23 on board DAC 205 rev 2V1 tanks for all the help I can get.
Sorry for my bad English
Best Regards
Lars
Mooly 9th January 2013 07:31 PM
It looks to be feeding the 5 volt regulator. If it does go to pin 1 on the reg then it will be a low value resistor, probably around 1 to 10 ohms. I would consider replacing the regulator (they do fail) and fitting a new resistor of say 4.7 ohms 1 watt and see what happens when you power up.
M-05 5th February 2013 10:00 PM
Thanks for reply :) I will change the resistor and regulator and see what happend.
Best regards
Lars
Copyright 1999-2017 diyAudio
