diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   PCM to DSD conversion solution (http://www.diyaudio.com/forums/digital-source/227101-pcm-dsd-conversion-solution.html)
narinari2106 5th January 2013 08:29 PM
Hi all,
Anyone has any ' PCM to DSD conversion by hardware' solution info?
I'm very interested, but I have info about ElectrArt's one only.
Please share any info.
(Especially hard info for diyer's needed)
enantra 17th January 2013 08:03 AM
hi
perhaps :
Amanero Technologies
regards
Jackal29a 17th January 2013 10:08 AM
The Amanero adapter doesn't perform any PCM->DSD conversion.
roygbiv9850 17th January 2013 02:21 PM
I don't understand why pcm to dsd?? it is no sens...
gmarsh 17th January 2013 04:01 PM
What's the application?
Bunpei 31st March 2013 11:52 PM
I think a combination of DSD1794A and PCM4202 satisfies your requirement.
JeffZhu 1st April 2013 01:39 PM
DSD over PCM is a de-facto standard. dsd
But there is few solutions about decoding the dsd stream from pcm carrier packet. I will develop a cpld program to do this decoding. Hope it will be a fun project.
analog_sa 1st April 2013 02:51 PM
Originally Posted by roygbiv9850 (http://www.diyaudio.com/forums/showthread.php?p=3329911#post3329911)
Plenty of sense. A DSD dac uses different filtering which many seem to think sounds better. There are software players which convert PCM > DSD on the fly but the OP is seeking a hardware solution.
RayCtech 1st April 2013 03:24 PM
It is much easier to use a ES9018 based DAC.
Program registers for PCM like it is configured for DSD...
Then PCM sounds identical or even better than any conversion to DSD.
But if you intend to use a different DSD DAC then I understand your needs...
analog_sa 1st April 2013 05:40 PM
Ray, never knew this was possible... thanks! I wonder if it's as straightforward as it sounds.
Copyright 1999-2017 diyAudio
