Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
TORX173: which pin is Signal Ground?
Old 31st December 2012, 05:00 PM   #1
reMC is offline reMC  Netherlands
reMC's Avatar
Default TORX173: which pin is Signal Ground?
Hi, I'm building a Toslink>Coaxial converter. I'm using the TORX173 input. I understand this receiver has a seperate Signal Ground? Does anyone know which pin it is? I'm not that technical so I can't figure is out from the datasheet.
Thanks a lot!
Old 1st January 2013, 10:44 AM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Pins 2 and 4 are GND. See the drawing under section 5 in the datasheet for how it should be connected.
/U.
TORX173: which pin is Signal Ground?Hide this!Advertise here!
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
Question re: Signal Ground versus HT ground Magz Tubes / Valves 29 16th June 2012 01:08 AM
LM3886 Pin 7 to Power or Signal Ground? GregH2 Chip Amps 4 12th March 2010 11:15 AM
TT signal ground v. chassis ground and hummmmmmm texaslonghorn Analogue Source 0 25th November 2009 02:30 AM
~14 VDC between chassis ground and signal ground... StalfoS Chip Amps 3 5th May 2007 08:26 PM
