| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello, I need some advice for my Digital source.
I am in the process of building a DAC (ebay kit with Dario's mod bom). Plus GC and possibly the o2 headphone amp. The plan was to use a CD Transport for the input to the DAC via Toslink module. Initially the CD was going come from my micro system (Aiwa something) which has Toslink OP. I have just been out and seen the following CD players and wanted to know if anyone would be better suited: Denon DNC-100 (Optical out and inbuild headphone amp) £35 Technics SL-PG-480 (Only line out) £20 Kenwood DPF-2030 (Optical output) £20 Which would be the best option, for my setup. I am assuming that there is not much difference when taking digital and putting it into a DAC? I was thinking about getting one of these and rehousing it, or possible putting the DAC inside. (This is particularly pertinent for the Technics as there must be a digital feed in there somewhere!) Is anyone worth spending the cash on or should I just stick with the Aiwa as my source? Many thanks. |
#2 |
SCHP-100X for your region. New transports are available through the 2nd market ("jobber") suppliers. A pretty nice cd player on it's own, just a little "clunky" in the UI department (or find a kid or little brother or someone who has one working and buy it, and a couple of laser/mechanism assemblies.
With a few mods can better a lot more expensive transport /DAC combos.As is has a Toslink output (at least the ones I have). Search for the Sony Playstation as cd player thread here at diyaudio. Can be modded for digital output. 75Ω coaxial output is better than Toslink. The Playstations were built to take abuse. Also consider a computer cd-ROM or DVD drive (also consider non-Bluray DVD players).
stew ☮ -"A sane man in an insane world appears insane." |
#3 |
Thanks for the response, I was also looking at the CD ROM solutions.
Just thought that one of the options listed above might be a steal for realtively small amount of cash. Interesting that Toslink is not as good as I would have thought, as it's optical it does not suffer from noise. Obviously it needs to be converted, but what is the other downside? Cheers. |
#4 |
early Toslink suffered from some quality issues and apparently jitter problems that create noise in the system (look here). Good fiber optic cables must be used (glass fiber preferred). The transceivers are much better now and more reliable. If cables have been bent or rolled up too tightly they can be damaged.
So as a minimum to ensure a good Toslink signal, modern transceivers are needed (so current production is most likely OK), as are higher quality cables, (again most modern cables should be suitable, but seek out cables with a known construction material) and cables that have not been bent or rolled up too tightly. Sometimes we have no choice regarding having to use Toslink or not. Many components now automatically provide Toslink without S/PDIF, but the signal itself is essentially S/PDIF. You can always add an RCA output and convert the output prior to the Toslink encoder. (you may have to pad down the signal to lower voltage before the RCA output (coax). I'd have to chase down the actual voltages.
#5 |
I'll stick with Toslink and see how it goes.
Cheers |
| WTB: CD-Pro CD-Pro2 CDPro DIY Transport HiFiDIY | HP8903B | Swap Meet | 2 | 28th January 2011 04:17 AM |
| WTB: CD-Pro CD-Pro2 CDPro DIY Transport HiFiDIY | HP8903B | Digital Source | 0 | 27th January 2011 05:02 PM |
| CD PRO 2 - The making of a high end CD Transport | Peter Daniel | Digital Source | 439 | 12th January 2010 08:09 PM |
| CD Player vs. CD Transport using CD-PRO2 module | tomchaoda | Digital Source | 27 | 22nd May 2004 08:29 AM |
| Page generated in 0.09154 seconds (100.00% PHP - 0% MySQL) with 9 queries |
