Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th December 2012, 09:14 PM   #21
PlasticIsGood's Avatar
Simple inverse:
Old 28th December 2012, 11:39 PM   #22
Shinja is offline Shinja  Japan
PlasticIsGood,
look closely the timing chart ,
in the DATA L row of I2S 8fs mode , it is annotated L1 R1 L3 above the chart.
and DATA R have R0 L2 R2 annotation.
it means the DATA L contains odd number of samples of 8fs signal and DATA R contains even.
one DAC of CDP-507ESD feeds the DATAL and WS/APT (and BCK),
the DAC outputs L1 and R1 at the next BCK from negative edge of WS/APT.
another DAC feeds DATAR and LE/\WS, then outputs L2 and R2 at the next BCK from negative edge of LE/\WS.
this is just the mechanism you presumed.
Old 29th December 2012, 04:07 PM   #23
Thanks, Shinja! I felt there should be an elegant solution.
I've never needed to understand a timing chart before, but in this case there's one pair of opposites too many for my head to grasp without an illustration.
Old 1st January 2013, 07:08 PM   #24
This idea went into Cambridge Audio's CD2, CD3 players and DAC3 (the original 80s one) didn't it but at x16 OS with 4 x 1541A chips? Or was it a different arrangment?
Have an advert somewhere that describes the arrangement in simplistic terms.
Stan Curtis says he spent time matching 1541As so that they were a closer match to each other than Philips provided with the S1s (probably custom matched Rs were too expensive to outsiders too ).
Need advice for a 93 Fender "The Twin" Topper Harley Tubes / Valves 23 7th January 2011 07:57 PM
6.5" and 8" Sony Subwoofer Drivers from Sony All in one HT Systems form109 Subwoofers 7 1st March 2010 03:14 PM
Fender "Evil Twin" Hi/Low output = same level jl_lensman Tubes / Valves 4 24th April 2009 10:49 PM
Fender "Twin Reverb Amp" has no output. Pioneer621 Tubes / Valves 8 21st January 2009 05:20 PM
Copyright ©1999-2013 diyAudio
