Audio Aero Capitale
Any one out there with experience in replacing the digital pickup in this player, its a SONY KHM310AAA readily available for just a few bucks. I ordered two of them and they install fine, the lens moves up and down but the disc does not spin. The old drive which gave up reading SACD but it does spin the disc and reads CD (sometime)
Any advise would be greatly appreciated
Peter
Administrator
Joined 2007
I'm not familiar with that exact pickup but have you checked to see if it has any static protection links fitted ? Many Sony pickups do.
These are usually a solder blob shorting the laser diode that is removed after fitting.
Probably does have a static jumper of some sort, but I can also add that I have seen a very high bad-out-of-box defect rate on allegedly real Sony KHM220AAA and later #'s dvd transports like this. I suspect a very high rate of ripoff clone parts in the parts resale market. Only way to be sure of propriety, it seems, is to order from Sony or a legitimately Sony-authorised distributor. Or to buy a good working Sony dvd player that uses the same KHM. Not sure what model range that would be for a 310.
Thank you both, there was indeed a static link on the pick up - removing it made the beam work but unfortunately not the horizontal movement of the mechanism, I suspect that they are both DOA what to expect for $14 delivered. Luckily I found two complete drives from NOS DVD players on Ebay for $ 20 each so I'm taking another chance with those seller guarantee that they work.
Thanks agin for your advise it is greatly appreciated
Peter
I would agree, it is just that the old transport works just fine - except of course that it have trouble reading discs - all the other functions are fine. There are just three cables to this thing 2 power and one ribbon data cable with keyed connectors so its pretty hard to screw up.
As far as the pickup being counterfeit it looks completely identical to the old ones (I have two of these in the shop right now) so I am faily confident that they are indeed Sony ones - price maybe being the only deterring factor.
Ill let you know how the two complete transports work out.
Peter
Got the two new drives in and installed the laser pickups and both are working now.
The Audio Aero players have a seriously "under designed" power supply PCB turns brown from excess heat and the Chinfa AC/DC module fails as well.
Heres my take on the re design of the supply
Good Listening
Peter
Good Listening
Peter
Just had the Chinfa module fail on my Capitole Reference. I'm thinking about putting in a complete new linear power supply. Do you have any info on the PSU Schematic / output requirements?
Well, i've found a whole list here:
KHM-310AAA DVD Laser Mechanism Optical Pick UP KHM310AAA
They are as follows:
  • Agfaphoto AGFA954 ( Sony KHM-310AAA )
  • Akai DV-P4765KDSM ( Sony KHM-310AAA )
  • Akai DV-R4040VSMK ( Sony KHM-310AAA )
  • Atlanta ATX-5500 ( Sony KHM-310AAA )
  • DEX DVP518 ( Sony KHM-310AAA )
  • DV-Tech D350 ( Sony KHM-310AAA )
  • Elenberg DVDP-2430 ( Sony KHM-310AAA )
  • Elenberg DVDP-2445 ( Sony KHM-310AAA )
  • Elenberg DVDP-2448 ( Sony KHM-310AAA )
  • Elenberg DVDP-2450 ( Sony KHM-310AAA )
  • Elenberg HT-111 ( Sony KHM-310AAA )
  • Elenberg HT-120 ( Sony KHM-310AAA )
  • Elenberg HT-450 ( Sony KHM-310AAA )
  • Hyundai H-DVD5000 ( Sony KHM-310AAA )
  • Hyundai H-DVD5002 ( Sony KHM-310AAA )
  • Hyundai H-DVD5004 ( Sony KHM-310AAA )
  • Hyundai H-DVD5005 ( Sony KHM-310AAA )
  • Hyundai H-DVD5006 ( Sony KHM-310AAA )
  • Hyundai H-DVD5008 ( Sony KHM-310AAA )
  • Hyundai H-DVD5010 ( Sony KHM-310AAA )
  • Hyundai H-DVD5014 ( Sony KHM-310AAA )
  • Hyundai H-DVD5015S ( Sony KHM-310AAA )
  • Hyundai H-HT5107 ( Sony KHM-310AAA )
  • Hyundai H-MS1104 ( Sony KHM-310AAA )
  • Philips DVP5101KX/51 ( Sony KHM-310AAA )
  • Philips HTS 3300 ( Sony KHM-310AAA )
  • Philips HTS 3320 ( Sony KHM-310AAA )
  • Philips HTS 3500S ( Sony KHM-310AAA )
  • Philips HTS-3610K ( Sony KHM-310AAA )
  • Philips HTS 5000S ( Sony KHM-310AAA )
  • Polar DV-3080 ( Sony KHM-310AAA )
  • Rolsen RDV-550 ( Sony KHM-310AAA )
  • Rolsen RDV-580 ( Sony KHM-310AAA )
  • Shivaki SDV-2007 ( Sony KHM-310AAA )
  • Sitronics 101X ( Sony KHM-310AAA )
  • Sitronics 111X ( Sony KHM-310AAA )
  • Sony DVP-NS355 ( Sony KHM-310AAA )
  • Sony DVP-NS585 ( Sony KHM-310AAA )
  • Sony DVP-NS585P ( Sony KHM-310AAA )
  • Vestel 2800 ( Sony KHM-310AAA )
  • Vitek VT-4005 ( Sony KHM-310AAA )
