Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Active Current Source for TDA1543
Old 12th November 2003, 01:09 PM   #11
stefanobilliani is offline stefanobilliani  Italy
Originally posted by Andypairo
I'd say it depends on which voltage you are operating it from.
If you use 5V it is probably too high, if you use 7V you can go even higher.
The output current is equal to Ibias (=2*Iref)- IDac , which is sunk by a controlled current sink.
Therefore the "zero" signal current for IDac should be 2.65 mA /2 (if we take the maximum value).
In your case with 2.2 mA Ibias = 4.4 mA and AOR should source about 4.4 - 1.325 = 3.075 mA * 1k = 3.075V
With 2.7 mA you probably saturated the bias current source at 5 mA (its rated maximum), so in this case we should have a theoretical 5- 1.325 = 3.675 V... not corrisponding to the actual value.
Can anyone explain why?
Cheers
Andrea
Ok Andrea ,
I apologie for non-precise numbers regardin my "effective working values".
I must say first that the current source runs in real life at 2.3mA couse the tipical negative voltage of the jfet is not so tipical and it is 0.254volt and not 0.3v.The vref as above mentioned is 2.120 stable with or without music. I measure 3.212 v at one channel output resistor that is something like 985 ohm.
That's all.
Old 12th November 2003, 01:24 PM   #12
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Stefano,
which Vcc do you use?
5V or higher?
Cheers
Andrea
Old 12th November 2003, 01:28 PM   #13
Default Updating
After correct measure of the crucial parameters I update the first post schematic:
If -Your- jfet looks like this for a 2.3mA current the resistor is 130ohm. Otherwise is better measure the jfet vgs for precise current setting.
2.7mA as shown in the first post is just too much
Old 12th November 2003, 01:34 PM   #14
Stefano,
5V or higher?
Cheers
Andrea
Aaah! Here we go ! I use now 6.15Volts
Old 12th November 2003, 01:44 PM   #15
Andypairo's Avatar
Well, with 6.15Vcc the "ideal" output voltage (halfway between the minimum and maximum value given by the datasheet) is (6.15-1.2-1.8)/2 +1.8 = 3,375 V, so I think you have a quite perfect idle voltage.
Cheers
Andrea
PS Do you still use your balanced version?
Old 12th November 2003, 01:59 PM   #16
I like very much balanced operation but I paused it for a while couse I was searching for a different PS to power it and a more detailed and precise sound .Now the ASR is battery powered and I use fets for the TDA 6.15volts. Finally , the current source .
Spectacular result...now I'm ready and back for the balanced version.
Old 12th November 2003, 02:06 PM   #17
Andypairo's Avatar
I'd be very happy if you could post a complete schematic of your setup... mine is halfway between Doede's and the convertus, but I think I'll include the ASR soon, so it will be ready for balanced operation!
BTW should the ASR (and its clock) have its own PS? (I guess so..)
Cheers
Andrea
Old 12th November 2003, 02:18 PM   #18
OK Andrea . I'll see what can I do to post a decent schematic of my setup.
Regarding the ASR the answer is yes.Currently I power it with batteries.One for the clock and one for the sinchronizer.
The difference between PS and battery here is noticeable.
Active Current Source for TDA1543Hide this!Advertise here!
Alternative Active Current Source for Aleph-X ?? EUVL Pass Labs 17 8th February 2012 03:31 AM
Active current source Nixie Solid State 7 4th December 2006 09:31 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Source for TDA1543?? jeff mai Digital Source 4 21st February 2004 07:46 AM
Active current source or power resistor? woody Everything Else 2 19th September 2002 03:33 AM
