Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Arcam CD192 CD draw not opening
Old 19th December 2012, 03:45 PM   #1
jeby is offline jeby
Unhappy Arcam CD192 CD draw not opening
Hi
This is my first post and i need some help in sorting out my Arcam CD192 CD player. I bought this off from a friend but the CD draw is not opening at all. It says loading as soon as you switch it on and when you press load it says open and then goes back to loading. I spoke to arcam and they said the drive belt is gone and it will costs 160 which is a lot of money. Has anyone encountered any issues similar to this and is it possible to buy the drive belt from third party replace it by myself? I opened the unit to see whether there is any damage but i cannot see anything. If you need pictures please let me know. Any help would be much appreciated.Thanks in advance
Old 19th December 2012, 05:33 PM   #2
poynton is offline poynton  United Kingdom
poynton's Avatar
160 is TOOOO much !!!!
If it is the belt, expect to pay around 10 and fit it yourself.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 19th December 2012, 06:04 PM   #3
Mooly's Avatar
Loading belts are common failure items across many makes and models.
You need to measure the old belt, determine whether its a round or square cross section and measure the approx cross section size and then source a replacement. I would expect to pay under 1 but of course there are delivery charges from suppliers. Belts are widely available.
Old 20th December 2012, 08:29 PM   #4
Hi Everyone
Thank you for your replies. I opened the CD player to look at the mechanism and the belt and everything looks fine so put it back and when i switched it on it starts saying close and i pressed load to open the tray and put a disc and the tray is closed as usual but on the display it still says close. I think the sensor for closing the disc is not working. any thoughts? thanks
Jeby
Old 21st December 2012, 06:32 AM   #5
Mooly's Avatar
I'm not sure what the exact mech is used in the Arcam but this type of fault is typically the loading belt... are you sure there is enough grip for it to complete the loading cycle ? particularly if the mech is "raised" to meet the CD. Also "end limit" micro switches can cause problems.
With the drawer opening/closing if you momentarily grip the draw it should stall the loading motor. If you can hear it keep spinning the belt is slipping.
Arcam CD192 CD draw not openingHide this!Advertise here!
Schematics for Arcam CD192 links idlehands Digital Source 0 25th February 2010 04:59 PM
Arcam CD192 service manual idlehands Digital Source 1 4th January 2010 06:20 AM
Wanted: Arcam CD93 / CD192 schematic or service manual len_scanlan Digital Source 1 4th March 2008 05:48 PM
Sony CD-X33ES CD Tray not opening-help? eldarvanyar Digital Source 7 14th January 2008 05:12 PM
Copyright ©1999-2017 diyAudio
