| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
so i Have Lampucera Maxi with CS4397 on DIP Adapter with 1-2 switch for 16/24bit (or either is it for sample rate, dunno). It has in digital path a 24/192 CS upsampler and DIR9001. Problem is it one day began to make harsh on one channel. It comes out of DAC, not analog (tube) output. It doesnt matter if its Optical/USB so i think it's Dac problem. All voltages of supply are just OK. On the board it says there can be put CS4397/98, or PCM 1794 for example which I want to try. If the board says I can put one of these, will it work if I would desolder the CS4397 and put PCM1794 instead? I deeply want to try Iout and just another DAC. Thanks |
| blown cs4397, next step? | kanifee | Digital Line Level | 6 | 30th March 2010 05:18 PM |
| If you have a CS4397/8, RUN IT DIRECT. | gripracer | Digital Source | 12 | 9th October 2009 12:40 AM |
| CS4397 I2C Mode | Mush | Digital Line Level | 0 | 29th April 2009 01:49 PM |
| dac pcm1794 vs cs4397 | evert1 | Digital Source | 2 | 19th October 2008 02:36 PM |
| TDA1541A vs. CS8414 + CS4397 | macsaif | Digital Source | 0 | 10th February 2005 12:52 PM |
