| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi everyone
I am trying to modify my Asus Xonar Stx sound card with the Lampizator upgrade and I need some help understanding the balanced outputs. The PCM1792 has a Iout+ and Iout- for the left and right channel respectively. I think I understand I need to make 4 Lampizator circuits to convert each of those I outs in to differential Voltage outputs. The ground of the lampizator circuit must be tied to each channel's ground on the PCM1792. My amplifier currently only has inputs for RCA Single ended inputs. How do I take these four Vouts from the I/V stage and convert them in to Single ended? Or is there a way to take the differential output at the chip and make it single ended before the Lampizator (saving me 2 valves)? I have heard you sometimes tie I- to ground but I worry about damaging my sound card. The link for the DAC's datasheet is here. http://www.6moons.com/audioreviews/weiss4/pcm1792.pdf Thanks so much for the help. V |
#2 |
A current output can be safely grounded.
#3 |
Thanks Oshifis, I suppose you are right. If I do ground Iout- would that mean Iout+ will output the whole of the signal? I can then simply build a Lampizator for the 2 Iout+ pins and ground the Iout- pins without any loss of signal quality?
Balanced outputs might be nice to have when I have the budget / knowledge to make a preamp that can take balanced inputs so I might make the 4 outputs in the end. If I do can I still simply use the Iout+ pins for the single ended RCA outputs and leave the Iout- going through the small resistor for the Lampizator without signal quality loss? Thanks again for the help. V |
| how to mix sound from notebook and external sound card and get headphones output | burence73 | Headphone Systems | 17 | 29th December 2012 07:58 PM |
| Creative Sound Blaster X-Fi sound card w/upgrade | GOWA | Swap Meet | 0 | 12th August 2012 09:05 PM |
| FS: LampizatOr Digi Lampizator kits (2) | Gopher2K | Swap Meet | 0 | 7th June 2012 07:08 PM |
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| How Lampizator CD tube player sound? | Akita | Tubes / Valves | 71 | 13th January 2011 07:47 AM |
