Primare laser change - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th December 2012, 09:46 AM   #21
Mooly's Avatar
OK
Whatever chip set it uses the RF will be available easily "somewhere very near" the socket the ribbon plugs into.
Old 18th December 2012, 10:53 AM   #22
tiefbassuebertr's Avatar
Originally Posted by Mooly View Post
The measurement of approximately 1.5 volts pk to pk is as viewed on a scope. There's no other way to do it. If its difficult to access then you can solder a wire tag to connect the probe to.
It does sound like a suspect pickup. Even 6 years or so back I returned two CDM12.4's back to the supplier (I won't name them but they are one of the biggest suppliers to the repair trade). I was sent a boxed "Japanese" made CDM12.4 mech that was absolutely unbelievable in quality. The RF was amongst the cleanest I have seen. The other pickups looked and even smelled used and dirty.
No easy answer I'm afraid.
Are the "made in Japan" versions NOS or are there in Japan the CDM12.4 laser pickups still under currently production ?
check out also this threads:
Are there Philips/Marantz CD Player Models with Loader "L1265" (L-1265) and CDM 12
VAM1204 VAM1205 VAM1206 VAM1250 VAM1252 VAM1254 CDM12pro VAU1254=CDM12.4 compatib
Stripdown/Clean of CDM12.4
Phllips CDM 12.4 transport compatible replacement
P.S. this Primare model is very similar to Thule's model CD150 (Spirit) where the loader model L1265 from the Philips model CDR765 is in use - go to post #14 about
Thule Audio Components - Overview
Old 18th December 2012, 05:32 PM   #23
Mooly's Avatar
It looked very much new stock but that was several years back. From memory it was supplied in a hard plastic "clam shell".
Don't know what new production is available now for the CDM12.4... sorry
Old 18th December 2012, 07:25 PM   #24
You would normally measure here (for example) on pin 8 of the SAA7345 (assuming thats what it uses)
Find the 2K2 resistor and clip the probe to that.
finally found some time and attached a wire to 8th pin of SAA7345 (1st three pics). The last pic is 9th pin of TDA1305 soldered to ribbon cable socket (was 10th before). I don't know, seems to me like same graphs as I uploaded above Moreover, when attached to SAA chip, pk 2 pk voltage is reduced by 10% roughly...
same company same parts and design, different chassis
thanks for the links, I got the point, the only trouble is where to get a decent CDM12.4 laser...
Well, it's not so bad actually though it skips on scratchy CDs... The only thing is to try another laser head, perhaps I would be more lucky next time. Alternatively I'll use some grease from the old mechanism as the new one came without any.
Also would be very delighted to correctly take pk 2 pk measurements as it seems i'm doing smth wrong...
Old 19th December 2012, 06:45 AM   #25
Mooly's Avatar
It seems like the digital scope can't resolve the waveform, it shouldn't look like that If that's the case and I wouldn;t like to say whether the amplitude can be relied upon either.
The level decreasing when on the 2K2 resistor will be due to scope loading due to probe and cable capacitance. At high frequencies those effects become dominant. A divider probe (divide by 10) reduces that effect a lot.
Getting a good CDM12.4 is a problem. Remember these are nearly 20 yr old now.
Another thought is when you describe "scratchy" discs. The CDM12.4 was never great at coping with such discs in the real world although a good one passes all the red book tests and more.
Post #54 here,
Test CD for CD player adjustment
Old 19th December 2012, 07:42 AM   #26
There is only one me known source to get an excellent CDM12.4 head:
Buy the mechanism from Marantz' CD7, model VAM1252. Unfortunately Marantz don't offer the head alone - only the whole mechanism for 250 until 300 euros (as replacement part, definitely NOS and not from currently production).
File Type: pdf Schema VAM1252 TDA1302 aus Marantz CD7.pdf (43.3 KB, 9 views)
Old 19th December 2012, 07:58 AM   #27
Post #54 here,
ok, then I leave it as it's now adjusted roughly to 1.5vdc p2p on 9th pin of TDA1305. Thanks again for the help
I wish I said I have at least that hope, but it's way too much for used Philips head
Old 8th February 2013, 08:19 PM   #28
Default Off-topic Question concerning Primare
Who know the modell of Primare's audio rack system from post #22 about the thread
Racks, how do you support your equipment?
Old 10th April 2013, 08:53 AM   #29
cheers,
it took quite a long time for me to make sure that all gained copies from ebay are real cr%^& and even the so called genuine parts that have some stamps and even rust do also skip tracks or do not read anything after the first couple of tracks at all. That is a nightmare
anyway, there is one thing that forced me to post it here.
I installed a genuine cdm laser in my primare taken from other well working player that was used to compare the readability of all these Chinese copies. It worked for several days having no issues at all like when it was in the other player. Then yesterday in the morning it instantly began to skip almost every track on 50% of CDs. The laser had been accurately cleaned before I swapped it to Primare. Anybody knows what that thing is? Does that mean that the laser is going to die or the primare is so good that even the original cdm cannot help it?
Old 10th April 2013, 10:15 AM   #30
Mooly's Avatar
I wouldn't like to say what is going on tbh. Once you have started fitting different pickups and are still having problem then a thorough investigation is called for. And this is where proper test equipment is called for. The RF signal is the biggest clue and it should look like this on a scope (pictures 8, 9 and 16) irrespective of the pickup/mech type. The CDM12.4 signal should look identical to picture 16 apart from amplitude which could be a little higher on the 12/4
Sony CDP790 and KSS240 Restoration Project
Looking for Primare A30.1 schematic or servicemanual mipepim Solid State 3 16th January 2013 01:40 PM
PRIMARE 202 ultima legione Solid State 0 23rd April 2012 09:14 PM
Primare CD31 schmtc ? Zen Mod Digital Source 3 16th January 2010 12:12 PM
What is the difference between the Primare 302 and D30.2? Please help... cartman Digital Source 1 21st May 2008 11:36 AM
Sphinx Project 9 cd motor not running after laser change muizel Digital Source 26 29th January 2008 08:05 PM
Copyright 1999-2017 diyAudio
