| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Has anyone done this? I ask because I am about to use a Tentlabs setup and will modifiy their XO ps with a silicon carbide bridge and was wondering what improvements I may expect. Regards
Evil looms. Cowboy up. Kill it. Get Paid. |
#2 |
is choosing a less facetious title...
none for this application, they often have higher dropout and are not what you would acll a 'soft' diode. no chance they will give lowr noise, which is the only thing important for a clock PSU
#3 |
don't the Cree SiC rectifiers have very low minority charge storage = clean recover ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#4 |
yeah they offer what they call 'zero recovery' i've used them quite a bit, they are actually nice diodes, but check out Nelson's measurements/comments on zero recovery/sic diodes (i'll see if I can find the link); they can cause a resonance.
the main disadvantage i've found from using them is quite a bit higher diode drop, so if replacing the diodes and diodes only in an existing design, you may find that it doesnt leave enough margin for the regulator. I found that they made what was a properly sized custom wound transformer less than ideal because of this factor. for an amp of your own design, they may present some advantages, but for a clock regulator I dont see the point. Last edited by qusp; 11th December 2012 at 12:19 AM. |
| Silicon carbide rectifiers | john dozier | Power Supplies | 11 | 18th March 2013 02:47 AM |
| Silicon carbide power mosfet | gmphadte | Parts | 0 | 3rd August 2011 04:04 AM |
| Silicon Carbide Schottky Diodes | poynton | Parts | 8 | 24th February 2009 02:16 PM |
| Silicon Carbide High Voltage Schottky!!! | Petter | Solid State | 10 | 5th February 2004 08:22 PM |
| Who knows where to get 1200v Silicon Carbide Schottkys ? | TugaTweaker | Tubes / Valves | 30 | 2nd September 2003 10:21 PM |
