| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
which one sound better ? why ? thank
#2 |
Hi
In both cases the sound is worse, in comparison with sole DAC, because there are no two completely identical DACs, everyone always have some disorder of parameters (in a case with R-2R).
sorry my wrong English |
#4 | |
I would have said the opposite. You're right on the fact that the DACs aren't 100% identical. But since theyr "drift", "distortion" or whatever you call it, is a kind of random error, placing multiple dacs will tend to cancel this, and will give you an output that is the mean value of all the dac's output. And this value will logically be closer to the real value you should get |
#5 | |
Dear ALL.
Subjectively, the parallel or differential connection R-2R give sounds worse for me. The HF are greased, but the sound is much better in single DAC connection. DDAC uses passive i/u, and the parallel connection dac ICs there is simply necessary for increase of a output current. BTW, TDA1543 is the rather poor chip, can be therefore degradation of a sound is not audible What have you found such good in these TDAs? Its single advantage is simplicity in use.Quote:
#6 | ||
Hi Õàëÿâùèê ,
Pedja |
#7 | |
| diff between dipole and IB | bser | Multi-Way | 6 | 18th November 2004 10:23 PM |
| Parallel amps & Parallel Voice coils? | officeboy | Multi-Way | 7 | 26th May 2004 08:12 PM |
| help with diff. output | Raj1 | Digital Source | 4 | 9th September 2003 06:03 PM |
| Page generated in 0.10153 seconds (75.08% PHP - 24.92% MySQL) with 11 queries |
