Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
I/V using opamps
I/V using opamps
Old 12th December 2012, 10:26 PM   #31
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
I/V using opamps
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 12th December 2012, 10:28 PM   #32
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Here is the second stage of my phono RIAA where you can see the principle. Ignore the name of the Opamp and the inbuilt EQ in the feedback loop.
Old 12th December 2012, 10:30 PM   #33
R21 is wrong but that does not matter in this discussion.
Old 12th December 2012, 10:31 PM   #34
Actually it says OPA1641 in blue.
Old 12th December 2012, 10:39 PM   #35
jcx is online now jcx  United States
Originally Posted by smms73 View Post
jcx , to compensate the ada4637 that is compensate to gain >5 , I think that is need a 10 ohms resistence in series with c1 ,or at high frequencies c1 will bring gain below 5 . Or am I missing something ?
R3 and C3 forms a snubber, and snubbers are very good in limiting (dV/dt).
I think adding r3 and c3 is a good idea and can be use with compensated to unity gain opamp.
nominally I chose the "noise gain" as ~ C3/C1+1
I included R3, trimmed its value to show less ringing on the Vin - the exact value depends on what the op amp Zout looks like at the gain intercept frequency - which may not be accurately modeled
but you could look at R3 as being in the noise gain ratio with the op amp Zout
you really shouldn't try this noise gain campensation with such a fast chip (or the much faster AD8067) without a 100+ MHz 'scope to see if there are problems, adjust the values from the sim
Old 12th December 2012, 10:56 PM   #36
Reality first!
I/V using opamps
Wow, thanks!
Dario
Old 12th December 2012, 11:17 PM   #37
My pleasure. If you try that please tell me how you like the result.
Old 12th December 2012, 11:46 PM   #38
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by EUVL View Post
Not in the CEN IV circuit.
The added bonus is that Zin of the IV now equals Zout of the opamp.
And since the open loop gain is >120dB, and open loop output impedance is <1k,
you can argue that the OPA1641 Zout in follower mode would be <0.001 ohm.
And no, I don't have measurements to prove.
But yes, we have a PCB and will try it out some time.
Patrick
Don't get too excited about this circuit. It's actually worse than a "normal" IV converter using opamps, either in terms of noise or distortion. I believe what you would want if you do this is the lowest possible output impedance for the opamp which is why I added the buffer.
Old 13th December 2012, 12:08 AM   #39
smms73 is offline smms73  Portugal
smms73's Avatar
c3/c1+1 is right .
but if you add R3 in series with C3, you should also add a resistor in series with C1 in this case a value 5 times higher than R3.
I think that there is no problem using lead-lag compensation in faster opamps.
Adding R3 as I said before is a good idea.
Thanks for sharing
SÚrgio Santos
Old 13th December 2012, 12:09 AM   #40
What is this Dirk ? Positive input grounded and all currents lost in a loop.
I can not see how this animal can amplify but it will eat some current.
I/V using opampsHide this!Advertise here!
AF filter using opamps - substitution of opamps neazoi Solid State 19 5th October 2011 04:01 PM
Need a better opamps msj965 Chip Amps 2 20th March 2010 05:34 AM
OPamps xaudiox Swap Meet 2 31st August 2006 02:40 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
Opamps seiko_citizen Swap Meet 7 3rd May 2005 03:09 PM
Copyright ©1999-2017 diyAudio
