| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#51 | |
before widespread factory internal zener zap offset trimming some op amps benefited from selection for low offset, or those with trim pins could have input stage nonlinearity caused distortion minimized by the Vos trim of course I have no idea what people are really talking about when attributing "frequency response" type "explainations" to op amp rolling - we can be fairly sure no "conventionally audible" frequency respose changes occur with decdent, "audio" op amps in DAC I/V circuits but if some are so certain of these changes then why aren't they exploring really new op amps, composite op amp circuits instead of going down the descrete garden path, "nfb" rabbit holes |
#52 |
Hi JCX, no dc offset from the Dac's thanks to Abraxalito and the dac offset nulling circuit he posted, so the dac/s was zero'ed to within a tenth of a millivolt each time when each i/v opamp was listened to. And I listened to many not just these two mentioned.
PCM1704 Help needed with higher dc offset from one channel Cheers George |
#53 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I agree George, opamps for I/V just do not deliver transparency. I have changed my view based on experience, because I used to go for them a few years ago. Try a passive filter (steep one, based on inductors and capacitors) before discrete I/V and prepare to be surprised
(Listening to passive I/V, 7th order elliptic filter now, can't go back).
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#54 | |
Cheers George |
#55 |
I've not played with the PCM1704 - why does the I/V resistor need to be as low as 10R? I know there are some issues with diodes conducting at the output which limits the compliance available. I have about 100mV signal on the output of my TDA1545s, noise doesn't seem to be an issue, but then I'm only feeding 16bits. The amp stage will dominate in noise terms for 10R source resistance so its worth exploring whether the resistor can't be bigger. AD603 works great for me, this has a built-in 100R resistor.
#56 |
I've just read and been told that 10ohms passive I/V gets the best out of the PCM1704 I don't know who to believe to be honest anymore.
That AD603 looks the goods if 100ohms input is as good as 10ohms. 3v output at 2ohms with 50mA and I think most of the dac noise is taken out within the dac so maybe no low pass filter is required maybe? Cheers George |
#57 |
If you delete the low pass filter it'll still sound better than pretty much anything else except TDA1541A. But with the LP filter in place, the sound goes up into another league altogether - completely gob-smacking (at least with my TDA1545s). This does rather depend on the amp stage after it, AD603 might not be as great performance as a discrete stage done well. Once you've heard the sound through the filter, I can't believe you'd ever want to go back...
#58 | |
I am currently not using any filtering (neither low pass nor otherwise to compensate the nos roll-off), and actually very happy as it is....but i read somewhere that bumping up the high frequencies make a huge positive difference ...
-------- TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling |
#59 |
Definitely worth trying a filter, even with TDA1541A. Its definitely also worth bringing up the droopy top end by some means. You could do that by adding on two more TDA1541As (if you're feeling fairly rich) and feeding them with an HEF4517 delay line to create a 3 tap FIR filter. Thorsten also says undoing the droop is definitely worthwhile, I think he does it by some passive LC circuit, though not sure of the details.
#60 |
Hi all,
This is my first post, so far and learned reading here. I'm doing the mod in a CD player Technics SL-P999, is a great player. This model mount a linear DAC converters: Four PCM56P (two per channel) I replaced on I / V stage the original operational M5238 by OPA2604, and I'm not happy with the result ... sound, poor, muffled, dull, veiled. I was thinking of replacing by AD825, because I need to be an double encapsulated SMD, and the power supply voltaje is a +7.9 and -8.1 (original design in factory) I have skills and experience, it is worked in Panasonic/Technics/National for 15 years repairing audio, and I have instruments, parts, and Service Manual for these players any suggestions? greetings http://i48.tinypic.com/5anex5.jpg Last edited by Trident; 23rd December 2012 at 12:26 PM. Reason: add direction for image |
| AF filter using opamps - substitution of opamps | neazoi | Solid State | 19 | 5th October 2011 04:01 PM |
| Need a better opamps | msj965 | Chip Amps | 2 | 20th March 2010 05:34 AM |
| OPamps | xaudiox | Swap Meet | 2 | 31st August 2006 02:40 AM |
| FS: Power Chip OpAmps and other OpAmps & D to A Converter | dtm1962 | Swap Meet | 4 | 12th January 2006 10:07 PM |
| Opamps | seiko_citizen | Swap Meet | 7 | 3rd May 2005 03:09 PM |
