Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Kenwood DP-4020 CD Player woes
Old 1st December 2012, 08:00 PM   #1
JesseG is offline JesseG  Canada
JesseG's Avatar
Default Kenwood DP-4020 CD Player woes
Hi all
I have an older Kenwood DP-4020 in quite nice shape. At least I think it is worth saving. It is producing static (yes, static) mixed in with the music.
This is not a hum or buzz, but random static - like a poorly tuned radio station.
I have replaced the output op-amp, but no improvement.
Is anyone out there familliar with this player or maybe has a service manual?
For that matter, has anyone come across this symptom in a CDP?
Help, as allways, is deeply appreciated
Jess
"If we crashed our cars as often as we crashed our computers, we'd all be dead!"
Old 2nd December 2012, 07:32 PM   #2
stephensank is offline stephensank  United States
I have never seen a PCM1700 dac chip go bad in any way, but there is a first time for everything. Otherwise, if the static seems to follow disc rotation speed, it is almost certainly either a platter motor bogging down, or a bad error correction RAM chip. If it's entirely random, and not the dac, it would most likely be a bad signal proc chip. The other possibility, not at all remote, is that there are electrolytic caps dying in the sig proc &/or dac areas, or in supply.
Old 3rd December 2012, 05:02 AM   #3
JesseG's Avatar
Thanks Stephen. with so many possibles, I am thinking that the way to trace this puppy is to record a simple sine wave onto a CD and then start working backward from the output jacks to the DAC. That is, if it is being generated in the audio stages.
Is it even possible for noise of this type to be generated somewhere in the digital circuitry?
Old 4th December 2012, 03:03 PM   #4
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Static charge/discharge
Hi Jesse.
Although I am far from being a tech...
... I'd suggest the output caps on the output stage and/or power supply. Not much help, and only a guess, but a reasonable suggestion I think.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 6th December 2012, 03:25 AM   #5
JesseG's Avatar
Yeah, thnaks Stew. I am planning to put it on the scope this weekend and see what I can see.
Old 6th December 2012, 08:14 AM   #6
Mooly's Avatar
Stephens suggestions above are sound.
Also if the signal from the pickup is marginal then it is possible to get this effect. Does the problem alter at all if the player is stood on end/upside down while playing ? If so then the problem could well be mechanical/pickup related.
Old 7th December 2012, 09:46 PM   #7
JesseG's Avatar
Thanks all - I have some things to test
Kenwood DP-4020 CD Player woesHide this!Advertise here!
Kenwood DP 2000 CD upgrade Saki_zg Digital Source 2 16th March 2011 10:38 PM
Kenwood DP-750 CD player JoMo Digital Source 0 1st July 2010 07:50 AM
Kenwood DP-X9010 and CD-R Rien Digital Source 1 1st June 2009 08:33 AM
Marantz CD-6000 OSE VS Kenwood DP-7090 -which is better? LifeIsMusic Digital Source 30 27th May 2008 08:07 AM
kenwood cd player usb jump drive issues ppia600 Car Audio 24 30th December 2007 12:53 PM
Copyright ©1999-2017 diyAudio
