CL-15 schematics: blowing mains fuse - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th November 2012, 01:52 AM   #1
Default CL-15 schematics: blowing mains fuse
Does anyone have a copy of California Audio Labs CL-15 schematics? It would help with diagnosing the mains fuse blowing immediately on power on.
Old 29th November 2012, 10:09 AM   #2
Mooly's Avatar
I can't help with a circuit but can say that if the mains fuse is blowing then its usually something fundamantal. Does it use an SMPS (switching) type supply. If so then failure of the switching element (transistor FET or IC) is likely together with other failed components. The underlying cause must also be found, usually electrolytic caps that have developed a high E.S.R.
Hopefully it uses a normal PSU and if so you should look for short circuit rectifiers on the secondaries, also check any filter caps across the mains supply and finally the transformer itself. Disconnect all secondaries and if it still blows the fuse then the tranny is faulty (rare but it happens).
Old 1st December 2012, 10:06 AM   #3
tiefbassuebertr's Avatar
I think, this is follow device:
California Audio Labs CL-15 CD player | Stereophile.com
First step in such cases is to disconnect the transformer secondary windings from the PCB's. Second step is the remove of the snubber capacitor in parallel to the two mains input leads - if present.
If now the mains fuse blowing again, the primary coil from one of the mains transformers are damaged.
Otherwise you will be happy, because all the other parts are not so expensive.
Before you start with your troubleshooting, call and ask there at first step:
repair@approvedaudioservice.com
phone: 860-567-5801
Old 17th December 2012, 02:01 AM   #4
phone: 860-567-5801
Thanks, and correct unit. There are two transformers with primaries in series with various taps to get multi-country voltages. One of these has overheated and is damaged.
With this arrangement it is hard to work out what the VAC of the various primaries are. It looks like 2x 15-0-15? (feed +15,-15V as per PCB markings) dual mono for L+R channels analogue & DAC, and two other windings probably for digital + and disk unit.
Also, it looks like there is a separate winding used on the transformer that feeds D708 then a 22k resistor—I suspect it is some sort of AC detect to cut power quickly on shut off.
If anyone knows what the transformer secondary VAC specifications are it would be helpful so I can replace with appropriate toroids.
Phase Linear 700B blowing mains fuse m6tt Solid State 34 22nd December 2009 07:47 AM
Cal Audio Labs CL-15 bungelow_ed Digital Source 0 8th July 2009 02:21 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Blowing B+ fuse trombone Tubes / Valves 5 1st July 2008 02:05 PM
Mains Relay blowing Fuse on GC k3ys3r_soz3 Chip Amps 2 6th March 2007 05:25 PM
Copyright 1999-2017 diyAudio
