Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD63KI problems - please help
Old 11th February 2013, 06:12 PM   #81
Mooly's Avatar
If you don't see anything on the RF (not that you should) when it does drop out then the problem is looking a bit deep seated and obscure.
I guess the next step is to use the scope to monitor the audio as early in the process as possible, which will be the output of the DAC's.
Old 20th February 2013, 01:28 PM   #82
nuryev is offline nuryev  Australia
Where on pcb can i monitor the DAC's output while cd player is connected and playing a cd?
NYV
Old 20th February 2013, 01:36 PM   #83
Mooly's Avatar
You would have to look at the circuit and see where the analogue stages connect to the DAC. Just follow the circuit back from the output sockets until you come to the DAC testing along the way.
Old 20th February 2013, 01:53 PM   #84
thanks for the quick reply. Do you recommend a scope or DVM for DAC output testing?
Old 20th February 2013, 01:54 PM   #85
Mooly's Avatar
Scope every time
Old 20th February 2013, 02:37 PM   #86
Thanks will keep you posted
NYV
Old 22nd February 2013, 07:20 AM   #87
Originally Posted by Mooly View Post
Good luck.
(have a read at post #10 here,)
UK Vintage Radio Repair and Restoration Discussion Forum
And watch the Molykote... if its like the stuff I remember from video mech repair day it gets everywhere.
I tried accessing the page via the link you provided but was denied.
NYV
Old 22nd February 2013, 07:29 AM   #88
Mooly's Avatar
Still works OK here but here's the latest URL,
Old 22nd February 2013, 10:42 AM   #89
Thanks for the suggestion to work back from outputs.
I have resoldered the TCA driver chips - as well as all caps and resistors on laser board, around the outputs and before and after the DAC chip. Removed opamps and tried with each channel disabled to eliminate the possibility of opamp failure.
I detected a 2.5v presence at the DAC pin 26 where 5v should be present....??
NYV
Old 22nd February 2013, 10:58 AM   #90
Mooly's Avatar
Is this 2.5 volts at some different value when the fault occurs ? In other words does it alter according to the fault.
CD63KI problems - please helpHide this!Advertise here!
Marantz CD63KI Biskit Digital Source 3 6th May 2013 06:21 AM
Marantz CD63KI Not Recognising CDs dlflclhl Digital Source 21 14th April 2013 09:33 AM
Cd63ki nad Digital Source 0 7th November 2009 08:05 PM
Clock for CD63KI Biskit Digital Source 12 24th September 2004 02:16 PM
Crackling/static noise from CD63ki SimontY Digital Source 5 3rd August 2003 09:23 PM
Copyright ©1999-2017 diyAudio
