Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD63KI problems - please help
Old 7th February 2013, 03:41 PM   #71
nuryev is offline nuryev  Australia
I finally got a dual trace analogue oscilloscope, an Aron BS601. Doing a lot of reading and fiddling with controls and still finding my way with the language and terminology. Hope to start the trouble shooting on the weekend.
NYV
Old 7th February 2013, 05:40 PM   #72
Mooly's Avatar
That sounds promising.
Old 8th February 2013, 03:32 PM   #73
Default Aron BS601 oscilloscope
It is only a 20mhz scope and I hope it is adequate. Although it is an oldie it looked clean and well maintained. Only time will tell if it is worth the $60 I paid for it - including probes.
NYV
Old 8th February 2013, 04:36 PM   #74
Mooly's Avatar
20Mhz is fine for most work. Remember, an analogue scope doesn't stop responding at its bandwidth limit, the response tails off beyond that point. It would probably resolve over 30Mhz at lower vertical deflections.
It looks a good buy.
Old 10th February 2013, 02:20 AM   #75
I managed to do a calibration test and got a nice square sine wave, dont know it that is anything worth mentioning. Now trying components tests but not successful yet.
NYV
Old 10th February 2013, 03:42 AM   #76
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
The calibration signal should be square. It should go up by the same distance, and for the same time, as it goes down.
A sine is a sine...if it were square the world would be very strange
Old 10th February 2013, 05:25 AM   #77
Oops!! Thanks for correcting me on that. Yes it is a square wave. Any info on using a scope to test caps, resistors and diodes?
NYV
Old 10th February 2013, 12:02 PM   #78
Default scope tests
First test results at testpoint 9 before and after audio drop out.
NYV
Old 10th February 2013, 05:13 PM   #79
Mooly's Avatar
That looks pretty decent as such. I'm not sure what the amplitude is as you would need to check the scope calibration, and make sure any variable attenuators on the V/DIV control are in the "CAL" position (those inner red controls).
So when the audio drops out I'm guessing you don't see any change in the RF ?
Old 11th February 2013, 02:32 PM   #80
The red controls are switchable and were clicked to the left in "CAL" position.
No change in RF when audio drops out.
NYV
CD63KI problems - please helpHide this!Advertise here!
Marantz CD63KI Biskit Digital Source 3 6th May 2013 06:21 AM
Marantz CD63KI Not Recognising CDs dlflclhl Digital Source 21 14th April 2013 09:33 AM
Cd63ki nad Digital Source 0 7th November 2009 08:05 PM
Clock for CD63KI Biskit Digital Source 12 24th September 2004 02:16 PM
Crackling/static noise from CD63ki SimontY Digital Source 5 3rd August 2003 09:23 PM
Copyright ©1999-2017 diyAudio
