Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD63KI problems - please help
Old 8th January 2013, 04:51 PM   #61
Mooly's Avatar
Is that the complete mech including pickup or just the pickup alone you replaced ? The fault is essentially unchanged from what you say though, it plays for so long before audio cuts out.
I really don't have anything new to suggest to you. Its a tough fault and it needs a scope to try and find a way in to what is going amiss.
Old 9th January 2013, 12:24 AM   #62
nuryev is online now nuryev  Australia
I replaced the pickup mechanism (motor and spindle) section. After getting no joy from that and noticing that a gentle tap on the rear of the mechanism gets it playing I checked and reseated the mounting rubbers.
NYV
Old 22nd January 2013, 04:10 AM   #63
Thanks for the links and suggestions for troubleshooting the faulty cd63i. I have taken a break from it all and will get back to review your suggestion re: audio muting circuit.
Thanks again.
NYV
Old 25th January 2013, 06:45 AM   #64
Extreme_Boky is offline Extreme_Boky  Australia
Careful visual inspection of the pcb should reveal cold solder joint and/or hot spot.
Boky
Old 29th January 2013, 02:35 PM   #65
Hi Boky
Thanks for the suggestion. I have repeatedly inspected the pcb and soldered most of the joints that looked 'suspect', even with magnification I may have missed something.
Would you be able to suggest which section of the pcb I should review? At least that would enable me to focus more intensely on a smaller area.
NYV
Old 29th January 2013, 10:29 PM   #66
The CD player works for a while and then it stops. To me this signals the hot-spot issue that results in loss of connectivity between the overheated pin (of the voltage reg for example) and the PCB track once the part overheats. The crack looks like very fine circle / crack around the pin that protrudes the PCB hole and solders on the underside to the PCB track. It is VERY hard to see this tiny circle, but it is possible - especially if you bend slightly the whole PCB - this reveals the problem and is easier to detect the crack.
Look underneath the voltage regulators and associated drop-down resistors. CD63 uses 4.7 ohm resistors before every Vcc / Vee pin - there’s a lot of those! Check those as well. They do not get hot, but are distanced from the PCB and could get bumped quite easily while doing mods.
Focus/tracking/sled servos use 3 analog, low noise IC’s that tend to run hot. I personally replaced at least 2 of those (TCA’s from memory...) because they failed! Check which TCA does spindle control and then use the freeze spray when the problem occurs.
Also, the transformer should be screw -tightened first and then soldered. If it is soldered first and then tightened -> the torque could put stress on the soldered transformer pins which will cack the solder joint eventually. This is very common problem with electronic products. Your CD player works most of the time so it is unlikely that transformer is the problem, but this is definitely worth checking.
Good luck
Boky
Old 30th January 2013, 01:19 AM   #67
I am/was apprehensive about bending the board but will do so when I check this time.
[/QUOTE]Look underneath the voltage regulators and associated drop-down resistors. CD63 uses 4.7 ohm resistors before every Vcc / Vee pin - thereís a lot of those! Check those as well. They do not get hot, but are distanced from the PCB and could get bumped quite easily while doing mods.[/QUOTE]
I have the schematic so identifying the Vcc/Vee resistors shouldn't be difficult.
[/QUOTE]Focus/tracking/sled servos use 3 analog, low noise ICís that tend to run hot. I personally replaced at least 2 of those (TCAís from memory...) because they failed! Check which TCA does spindle control and then use the freeze spray when the problem occurs. [/QUOTE]
During play the machine continues to display time, track, number of tracks left etc - even during audio drop out, and normal display continues until the end of the cd. Is this still possible if spindle control TCA is faulty? One of the first things I did was to drip freeze spray onto the 3 TCA's but this did not identify the fault.
[/QUOTE] Also, the transformer should be screw -tightened first and then soldered. If it is soldered first and then tightened -> the torque could put stress on the soldered transformer pins which will cack the solder joint eventually. This is very common problem with electronic products. Your CD player works most of the time so it is unlikely that transformer is the problem, but this is definitely worth checking.[/QUOTE]
The cd63ki has a torroidal transformer and although I did resolder all the tx/pcb connections, I didn't think this would apply, but it does make sense. It will be rechecked while the machine is dismantled.
Thanks for the time taken to draft such a detailed and informative response.
NYV
Old 30th January 2013, 01:43 AM   #68
Iíve forgotten the CD player continued to spin the disc and that the only problem was audio drop-out.
Iíve diged-out the CD63 diagram: Check the smd SAA decoder and DAC chips; make sure all the pins are soldered to the PCB, especially on SAA decoder chip. I had few CD52ís where SAA chip pins were losing conductivity with the PCB. Had to re-solder them and all was good again.
Also, trace the signal after AF test point and see what causes the audio signal chain to break. It could be anything really, so this would be the quickest and most productive way to approach this fault. Youíll need a CRO.
Boky
Old 30th January 2013, 03:56 PM   #69
I did the pcb check today - found the two regulators Q801 and Q802 were a bit shaky - i bent the pcb and found that the tracks to Q801 appeared to have hair cracks so i remedied that. Checked other joints for dry solder spots flexed the board under bright light and used magnifying glass.
Reassembled and tested only to find 'disc' being displayed. Reset the ribbon cable and ensured good connection then checked the QM01, Q106 and Q105. Two out of the three
generated voltages as per manual spec, but Q105 had 0V at pins 5, 6 7 and 8.
Looking at replacing Q105.
Where is the AF test point - I have Velleman 5mhz digital scope that did not seem adequate to do the test.
NYV
Old 31st January 2013, 06:22 AM   #70
Reset the ribbon cable and ensured good connection then checked the QM01, Q106 and Q105. Two out of the three generated voltages as per manual spec, but Q105 had 0V at pins 5, 6 7 and 8. Looking at replacing Q105.
The ribbon cable has many little ribbons glued-on to the plastic substrate. These individual ribbons can lift of the plastic, which will result in complete loss of conductivity - check that as well.
Q105 controls the sled and turns on the laser diode. If you measure 0 V on pins 5, 6, 7 and 8 then you may have faulty servo controller TDA1301T. You should also check the +5V DC supply and R129 (10K). Check Vref and R124 and R125 voltage divider.
You may as well check the ceramic resonator X101 (8.46 MHz) for correct frequency. The CRO you have can't handle it -> you'll need something like 20MHz CRO...
The AF test point I referred to is the test point 9 on the circuit diagram. I tend to always start from there - this segregates the player in to mechanism & servo control section, and filter/DAC/analog section. Test point 9 is "in front" of R501
Boky
CD63KI problems - please helpHide this!Advertise here!
Marantz CD63KI Biskit Digital Source 3 6th May 2013 06:21 AM
Marantz CD63KI Not Recognising CDs dlflclhl Digital Source 21 14th April 2013 09:33 AM
Cd63ki nad Digital Source 0 7th November 2009 08:05 PM
Clock for CD63KI Biskit Digital Source 12 24th September 2004 02:16 PM
Crackling/static noise from CD63ki SimontY Digital Source 5 3rd August 2003 09:23 PM
Copyright ©1999-2017 diyAudio
