Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CD63KI problems - please help
Old 6th May 2013, 06:01 AM   #91
nuryev is offline nuryev  Australia
Originally Posted by Mooly View Post
Is this 2.5 volts at some different value when the fault occurs ? In other words does it alter according to the fault.
Sorry for the long delay in replying to your response.
I have since found that a resistor of incorrect value was used - and this reduced the voltage from 5v to 2.5v. The correct resistor has been intalled. The voltage is now corrected to 5v as per service manual. The voltage does not alter according to the fault.
NYV
Old 30th May 2013, 04:35 PM   #92
Problem persists!
Had some time to look a CD63KI again - have noticed that at audio drop out voltage(s) at pin1 or both opamps changes from 0v to 0.5v (Left channel ) and 1.6v (right channel). Depending on cd being played. Voltages have fluctuated on pin1 of both opamps from 0.5v up to 2.6V!!????
NYV
Old 30th May 2013, 04:39 PM   #93
Hi again Mooly, I have been fortunate to receive a 50mhz scope from a friend! Still learning how to use all the controls and can now look at cd63ki with a little more confidence.
I also noted at audio drop out pin1 (both opamps) has a voltage change from 0v to 0.5v and 1.6v even as high as 2.6v!! depending on what cd is being played.
NYV
Old 30th May 2013, 04:59 PM   #94
Mooly's Avatar
I really don't know what to suggest to you with this problem, its obscure and deep seated.
Its always worth checking supplies when anything odd happens. Check the rails to the opamps with the scope and see if anything shows on either rail when the drop out occurs. Do the same for any supplies to the DAC. It probably has more than one supply.
If that gets nowhere then you have to use the same technique and go around all the pins on the DAC with the scope and see if anything shows when the drop outs occur. Its then a matter of interpretation as to whether anything observed is a fault or whether its the DAC responding to a problem elsewhere. It could be anything I'm afraid.
Old 2nd October 2013, 06:50 AM   #95
Hi Mooly, I took a break from the CD63 with the 'gremlins' but now I have a few days leave so will look at it again.
NYV
CD63KI problems - please helpHide this!Advertise here!
Marantz CD63KI Biskit Digital Source 3 6th May 2013 06:21 AM
Marantz CD63KI Not Recognising CDs dlflclhl Digital Source 21 14th April 2013 09:33 AM
Cd63ki nad Digital Source 0 7th November 2009 08:05 PM
Clock for CD63KI Biskit Digital Source 12 24th September 2004 02:16 PM
Crackling/static noise from CD63ki SimontY Digital Source 5 3rd August 2003 09:23 PM
