| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I plan to build a DAC with DIR1703 + AD1853 + active I/V stage and some ASRC (AD1896 or SRC4192).Which i should choose? The SRC4192 has a little better specs,but in datasheet there is no jitter attenuation characteristic like in AD1896... Please help me! Marek. |
#2 |
I think the answer is that it is still a big unknown which IC is better in practice.
#3 |
Since the SRC4192 and AD1896 are footprint compatible, why don't you try them both? You won't need a separate board layout.
The SRC4192 requires an external oscillator for its internal logic, it doesn't have the circuitry to use a plain crystal like the AD1896 does. The AD1896 can also work with an external oscillator. So as long as you put an oscillator on your board for this (probably best to use 30MHz), you can use either. Brian. |
#4 |
I continue to use the Analog part, simply because the Analog datasheet explains in depth the workings of their circuit, and although I'm sure TI/BB has talented people, their datasheets seem consist mainly of errors, confusion, and misinformation. It makes me wonder if they really understand their own products.
#5 |
Indeed . You would think it worth the minimal cost of creating a good datasheet when balanced against the volume of ICs used and the free advice doled out by their support engineers ($$).
| How to connect CS8414 to SRC4192? ( 5V->3.3V) | dieringe | Digital Source | 10 | 12th October 2006 05:44 PM |
| SRC4192 Use... | MWP | Digital Source | 33 | 26th April 2005 07:17 PM |
| SRC4192's are on the way... :) | Tieftoener | Digital Source | 27 | 25th November 2003 08:36 PM |
| New ASRC - TI SRC4192 | tiroth | Digital Source | 1 | 27th August 2003 10:49 AM |
| Page generated in 0.07977 seconds (74.24% PHP - 25.76% MySQL) with 10 queries |
