hum issue with Audiosector DAC hum issue with Audiosector DAC - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th November 2012, 09:27 PM   #1
vinylnvalves is offline vinylnvalves  United Kingdom
Default hum issue with Audiosector DAC
I am trying out an audiosector DAC, and am running into problems.
When i connect the DAC to a squeezebox Touch (RCA to BNC) i am presented with very loud noise which swamps the music. This noise is present as soon as you connect the power to the touch.
If i connect the DAC to my Audionote CDT there is no noise, equally when i connect my Audionote DAC to the Touch i have no noise issues.
Has anyone experienced anything similar? Iinitially assumed it was an earth loop issue but am not sure because I notice that the Audiosector DAC has a floating ground and the Touch is not earthed so the only earth path is via the preamp, so no loops.
Old 16th November 2012, 11:29 AM   #2
I was just thinking - should the DAC have a floating ground, or should GND a and GND D be connected to the incoming mains ground?
Old 19th November 2012, 10:16 AM   #3
syklab is offline syklab  Mongolia
Could it be the noise coming from your Touch's power supply?
Old 19th November 2012, 04:16 PM   #4
jitter is offline jitter  Netherlands
jitter's Avatar
Please describe the noise.
Old 23rd November 2012, 09:19 PM   #5
haik is offline haik
Can you connect a scope to the output (without audio, or only with a test CD signal), and make a snapshot and post it here?
hum issue with Audiosector DACHide this!Advertise here!
Audiosector USB DAC Peter Daniel Audio Sector 76 21st October 2014 08:56 PM
Hum issue e_fortier Class D 6 3rd March 2009 02:42 AM
Audiosector NOS Dac Darrell Morgan Digital Source 7 8th August 2007 02:55 AM
audiosector dac karma Chip Amps 3 7th December 2005 01:04 AM
VERY loud hum issue 5th element Solid State 23 30th May 2004 05:37 AM
Copyright ©1999-2017 diyAudio
