| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi!
My CDP has a chip that I can't really figure out what's doing. It is a Philips chip with 44 pins and is marked: QC8868HP K5D770CA Can't find data sheets anywhere or anything. Has anyone got a clue? help appreciated! b.t.w. it is not the DSP, there's an SAA7345 in there too; and probably not the dac as there's also a TDA1305. /cdl |
#2 |
I would say it's a controller. Where is it located, near the drive, or on the display/buttons board ?
Just my 2 cents
/Cheff - Falling feels like flying, until you hit the ground |
#3 |
We might find something if you give us the model nr. of the player (on the backside) and the position number of the chip on the pcb.
/Hugo |
#4 |
Sounds to me like the controller indeed. How old is that player? Could be a derivative of the 8800 or 6800 microcontroller series that were used by Philips before they switched over to 8050 series.
Jan Didden |
#5 |
Hi Guys, ta for the responses!!!
First of all, my apologies, the chip is labeled OQ8868HP and not QC as I stated earlier. Damn that small writing... needed a magnifying glass to see the text clearly. Which makes stuff easier... I found out what it is! It's the "digital servo" apparently for the laser mechanism of the transport (CDM 12.4)! It IS puzzling that a search for "*8868*" on the Philips Semiconductors site didn't return any useful hits... must be a lousy search engine! So maybe I should get better glasses On the other hand, nothing is wasted - your responses prompted me to have a closer look at the fellow with a magnifying glass, and whilst doing this I: 1) found out what the actual markings of the chip were a.s.o. 2) discovered a resistor I must have fried while installing the Elso's clock (my own fault , NOT Elso's )So thanks - this forum really is a great place! Cheers! |
| Mystery RF amp | spooney | Car Audio | 11 | 25th April 2008 06:14 PM |
| little 6.5 mystery ... | oface | Full Range | 6 | 4th November 2007 11:20 PM |
| Mystery driver. | G | Full Range | 4 | 23rd April 2007 06:37 AM |
| Mystery SE OPT | alexmoose | Tubes / Valves | 4 | 11th July 2006 01:29 AM |
| mystery... | mista2 | Multi-Way | 1 | 14th January 2005 04:20 AM |
| Page generated in 0.07933 seconds (74.78% PHP - 25.22% MySQL) with 10 queries |
