Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Oppo's BDP105 - discussions, upgrading, mods...
Old 23rd January 2018, 05:26 PM   #1781
3djacob is offline 3djacob  Denmark
Hi Coris
I have a OPPO BDP-103 which I have upgrade a little.
1) I have change the IEC power inlet to a Furutech NCF IEC power inlet, plus 230V power the cables is also changes to Cobber/Silver cables.
This has improved the sound a little, there is more power on the colors
2) I just ordered a linear power supply, which I expect a lot from.
I did "only" buy a BDP-103 because I use an external Hi-fi DAC, so sound quality out of the analog side does not interest me.
I use the optical output into my DAC.
I was wondering if I could improve the picture quality further by replacing some of the clocks to reference clocks in the BDP-103.
Which clock would you recommend to upgrade if I chase /go after picture quality?
1) The 27MHz for the main processor.
2) The 20MHz for the HDMI Marvel chip.
3) Both.
If you say 3) both could you give a short example on what to expect for each clock upgrade ?
I have added a link to the clock which I already have and intend to use.
NewClassD Neutron Star
Thanks in advance :-)
Br
Jacob Land Jensen
Denmark
Old 25th January 2018, 03:04 PM   #1782
Hi All
Does anyone else have an view on clocks in a OPPO to improve picture quality?
or an answer to my question ?
Br
Jacob Land Jensen
Old 25th January 2018, 03:15 PM   #1783
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Anyone interested here in an unmodified, stock OPPO BDP-105? Mine is surplus, make me an offer, you'll have a machine you can mod to your own delight!
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 25th January 2018, 08:58 PM   #1784
Coris is offline Coris  Norway
Coris's Avatar
Hi Jacob
Both clocks should be replaced. The original ones are only resonators, driving a PLL inside the chips. The overall result of replacing these clocks is an improved picture quality (more fine details, less noise, improved colours and contrast, richer tonal range). Also the linear power supply for main board is a important factor for improvements.
Also for the best picture improvement is investing in the new model 203 (+ new clocks, and linear PSU)...
Old 27th January 2018, 08:57 AM   #1785
Hi Coris
Thank you for feedback!
I don't need the analog stage, so I got the idea to disconnect its power and the flat cable to the main board.
This way do I minimize power consumption, heat and unneeded noise in the OPPO.
I could also use the +15V for powering the clocks, they run best at +15V
Do I destroy / disable any of the other function by disconnection the analog stage ?
Br
Jacob Land Jensen
Old 27th January 2018, 10:43 AM   #1786
Coris's Avatar
Hi Jacob
The device it can function very well with the analogue stage fully disconnected. No any issue.
Old 31st January 2018, 07:52 PM   #1787
Hi Coris
I am not going to upgrade my OPPO BDP-103, because I had a accident
I was trying to dismount the plastic clips for the "radiator" on the main processor and then my screwdriver slipped and did cut a lot of copper lanes to the HDMI connectors
Is your LPM for the OPPO BDP-203 commercial or have you only made for your self ?
If the LPM are commercial could you give me a hint where I could buy one in Denmark?
As upset as I am do I like to see the good things is life, so now do I have the opportunity to get an OPPO BDP-203 even I don't have a 4K TV jet I dont want another BDP-103 even I liked the machine a lot
Br
Jacob Land
Old 31st January 2018, 09:00 PM   #1788
Coris's Avatar
Hi Jacob. You have a PM.
Old 13th April 2018, 02:29 PM   #1789
inline_phil is offline inline_phil  United States
I have been monitoring the group for what seems like forever and observed many excellent contributions. This one may be of interest since it is another essentially zero cost upgrade.
My BDP-105 main board developed an HDMI switching issue and I ordered a replacement board from OPPO. to R&R this board, you must pull out most of the other boards, pretty easy to do just a lot of screws. I noticed that all pads on the PC board were ground points and being a long-time believer in removing them I decided to buzz out which were redundant. Answer: almost all of them [top and bottom].
As I replaced each of the boards, I added electrical tape over these ground-loop causing pads and reinstalled the boards.I also isolated the RCA output jacks in a similar manner [tape on the ground pads and the outside of the chassis]. This keeps the pads and the screws from causing another ground loop.
Checking the pads on the digital power supply PC board yielded exactly the same results [the pad closest to the power inlet is the culprit here]. Taping the pad and not installing the screw is the option I chose for this one. Plus moving the ground wire of rear of the IEC socket from the chassis to the last screw nearest the rear panel onthis same digital PC board [opposite the now removed screw] puts the chassis ground at the same potential as the digital supply ground as the power inlet ground. This ground IEC ground wire must be lengthened since its current length will not allow it to reach its new location.
The results were mind blowing. First, the video blacks were plasma-like on my Samsung F8000 TV. This made a huge impression on my wife, the one who assures that my tweaks were real as opposed to the "It must be better because I did it" syndrome. Second, the sound - well, the sound stage is massive, pinpoint detailed, and highly articulated. The difference in the size of the sound stage between well produced studio recordings and a live recording is shocking and immediately noticeable. For example, when playing a well recorded organ piece in a cathedral I could close my eyes and see where each of the ranks were positioned L-R, F-B, T-B, and when the doors opened and closed [could hear a slight slapping also]. Well made studio recordings - Dire Straits "Fade to Black" - produced some of the most accurate reproductions of Mark Knopfler's guitar I have only heard on systems with astronomical price tags.
You must give this mod a shot if you do nothing else to your OPPO. I can say with good certainty that any of the OPPOs ever made would respond in similar ways - search out and remove those nasty ground loops!
Old 13th April 2018, 02:36 PM   #1790
Staudio is offline Staudio  Russian Federation
Hello. It is really interesting! Could you take photos of your improvenents?
Oppo's BDP105 - discussions, upgrading, mods...Hide this!Advertise here!
OPPO 93 and OPPO 95 - A warning. sandyK Digital Source 3 26th January 2012 06:53 AM
Discussions about your favorite or DIYD/T-amp v-bro Class D 0 13th January 2009 08:37 AM
Class D discussions mskeete Class D 16 19th March 2004 06:27 AM
Discussions on Balenced Amplifers theChris Chip Amps 24 6th January 2004 02:40 PM
Do opamps discussions also have to take place here? Bricolo Chip Amps 3 27th April 2003 08:39 PM
