Oppo`s BDP105 - discussions, upgrading, mods... - Page 93 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th March 2014, 09:48 PM   #921
Coris is offline Coris  Norway
No problem about your last posts...
Yes, indeed, damping the transport device it bring some noticeable improvements (when playback from discs).
There is a mechanical design problem with the discs player in 105 (as in the earlier models).
I think I have explained this in the 95 thread. This transport it is mounted in a very rigid meaner inside the player enclosure. Oppo used some quite powerful springs in a wrong meaner, thinking this way it will be some damping... The springs only press very heavy the transport enclosure to the player cabinet, in a very rigid construction. Here is the big clue to be done some modifications.
Such mod is quite complicated, but it may bring the best results. I have replaced the original springs with some silicon dampers fabricated for hard discs use. As a result, the transport in my player just float free, sitting on these silicon things.
You may try to find the description of this mod in the 95 thread, I think in the beginning of it. There are some pictures there too.
Old 6th March 2014, 09:57 PM   #922
This mod is described here (actually in this thread):
and here:
Old 31st March 2014, 04:50 PM   #923
eganz1 is offline eganz1  United States
Default Linear power module
I just installed the linear power module from Jae Hong Lee for the OPPO-105.
He describes it here: Jae H. Lee Blog :: OPPO 95, 105 and 105D LPM upgrade V. 3 and here: OPPOMOD - About
This is easily installed, and involves temporarily removing the multichannel board, and then permanently removing a support strut, and the original switching power supply for the digital board and the disc drive.
The unit is well-built, and uses the original cables for hookup.
After installation, disc playback especially seems improved, and in general the noise floor seems lowered.
Eric
Old 31st March 2014, 10:31 PM   #924
... and the temperature inside?
Old 31st March 2014, 11:12 PM   #925
Joe Rasmussen's Avatar
Probably quite a nice add-on, but my argument would be that I am achieving the same and possibility better, at much lower cost. So I believe is Coris.
Where is the worst noise? Identify that - and it may not be where you think it is. The solution some of us are using absorbs noise generated by the DAC itself and also acts as a second order filter attenuating noise from the power supply as it LC, relying on some inductance feeding the C. Then the remaining problem would possibly be airborne, but use a zero-feedback post-DAC circuit that won't suffer slew rate problems, and you have all bases covered.
Admittedly, that last bit may not be low cost - but IMO the best choice, no opamps.
Cheers, Joe
The "Elsinore Project" DIY Speaker System " & DIY "Trans-Amp" - 40 Watt Transconductance Amp
Soon: High Frequency Bias in Tube OPT - "Don't take anything I say as an affirmation but as a question."
Old 1st April 2014, 12:28 AM   #926
Calling himself OPPOMOD - is that not a TM infringement?
Old 1st April 2014, 08:45 AM   #927
I do not want discourage (give up) eganz1, but I will express my point of view regarding the switching PSU in Oppo player, and in general in a digital system.
Feeding a digital system with linear power is only positive, thinking the quality of the approach. But when a digital system use quite much current, the efficiency of a serial PSU degrade much in such case. The big cons of a serial PSU is its heat dissipation for important currents.
On the top of this cons it come another one, which it negate the benefits of a cleaner serial PSU. A digital system is noisy by its way to work. This is a very solid fact! The only way to reduce the digital system noises is filtering, and shielding the eventual EMI noise generators. So, using a serial PSU, one feed the system with a clean power for a very noisy device/load. Benefit/result = 0 (nonsense). More, one get quite much heat from the working serial PSU...
What is to be done (more reasonable)? Minimise the noise generated by the switching PSU itself. Long connection wires between the PSU and the targeted circuits, is just bad. This is the case of Oppo players. Long connection wires act as good emission antenna for the HF noises of the SMPU. Solution: better power rails decoupling, shielding of sensitive circuits, better filtering out the HF noises.
In the Oppo player case, the SMPU is meant to power the mother board of the player, and the CD/BR transport (which it need quite important currents). The analogue stage (lower current hungry) it use already a separate serial PSU. This approach of the design is very reasonable. So it have to be.
In my opinion, the only improvement one it may bring to the digital stage, powered by a SMPU, is to specially care of powering the oscillators with a very good (low noise) local PSUs. This exclusively clocks dedicated PSUs it may be a serial regulator, shunt regulator, battery. The impact of cleaner power for the system clocks is quite high for both audio and video stages of the player.
I still think that the SMPU in Oppo is in the right place. Only some corrections it may be done to lower the SMPU EMI noises, even more. For production reasons, Oppo did not paid attention to such details...
Else, I think Oppo Company should react when somebody use its marketing name, to promote another or himself products... Or OPPOMOD it may have the right permission from the Oppo Co.? Anyway, this is another story and not our business...
Old 1st April 2014, 09:11 AM   #928
Originally Posted by Coris View Post
I do not want discourage (give up) eganz1, but I will express my point of view regarding the switching PSU in Oppo player, and in general in a digital system....
Hi Coris, pretty much agree with all you just said. Cheers, Joe
Old 1st April 2014, 01:59 PM   #929
Coris,
The linear power supply runs cool. It has a heat sink inside which also wraps around the bottom and touches the bottom of the case. I added some Arctic Silver thermal interface material to couple the heat sink to the bottom of the case.
I wanted a solution that was easy and quick to install, as I didn't have time to goof around with the SMPS.
Eric
Old 1st April 2014, 03:33 PM   #930
That`s nice! I understand your point...
OPPO 93 and OPPO 95 - A warning. sandyK Digital Source 3 26th January 2012 06:53 AM
Discussions about your favorite or DIYD/T-amp v-bro Class D 0 13th January 2009 08:37 AM
Class D discussions mskeete Class D 16 19th March 2004 06:27 AM
Discussions on Balenced Amplifers theChris Chip Amps 24 6th January 2004 02:40 PM
Do opamps discussions also have to take place here? Bricolo Chip Amps 3 27th April 2003 08:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
