| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#81 | |
This player (95) have some benefits, the best DAC chip at the moment, the transport, some connections possibilities, a very good video chip processor, and so on, but the analogue stage (power and after DAC processing) it were (is) not as it should be (in my opinion). The 105 model it have even more improvements, an asynchronous DAC stage (still yet to see how it works...), better main processor, better transport, and so on, but it seems (from the first view) that the analogue stage is even worse than in precedent... Still yet to hear it, but for this one may buy it first... I think maybe I will do it at last... For the moment I`n not very decided. Anyway it may be modded this model too... |
#82 |
Do you have an discrete I/V stage? It may be more simple design when one use just opamps for a such stage.... Only two components: the op amp and its I/V resistor... Another one for final and that`s all...
#83 |
#84 |
It seems to me that 103 have not AC coupling on outputs... Those caps around the opamps are for sure decoupling ones on power rails. It looks like the designers were thinking to improve the outputs of an more expensive player model, mounting those AC separation caps on output channels...
#85 |
Ceramic caps in the supply for IC ;s ?
#86 |
Yes... maybe you right. Then it could be the other ones AC coupling... It looks like we are caps detectives...
#87 |
There are NO ceramics in the audio path.
#88 |
is choosing a less facetious title...
103 is a much better design....
#89 |
#90 |
| OPPO 93 and OPPO 95 - A warning. | sandyK | Digital Source | 3 | 26th January 2012 06:53 AM |
| Discussions about your favorite or DIYD/T-amp | v-bro | Class D | 0 | 13th January 2009 08:37 AM |
| Class D discussions | mskeete | Class D | 16 | 19th March 2004 06:27 AM |
| Discussions on Balenced Amplifers | theChris | Chip Amps | 24 | 6th January 2004 02:40 PM |
| Do opamps discussions also have to take place here? | Bricolo | Chip Amps | 3 | 27th April 2003 08:39 PM |
