Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
S.houBed DAC 132db Dual MONO pcm1794
Old 30th November 2012, 08:53 AM   #21
xslavic is offline xslavic  Moldova
THATS all
next version 1.1 thinking to add a tpa6120 Headphone amp with JFET buffer for full V swing of your superlux headphones
or mine
Old 30th November 2012, 09:26 AM   #22
Bottom pcm1794 with pin1pin2 soldered together
Old 10th December 2012, 10:23 AM   #23
ATTention ,important note pin 3 and 5 of the opamps are connected together -connect them to ground
also as you see voltage is set for +-12 so its 24V total
you can lower it
Old 13th December 2012, 10:57 AM   #24
replace 8k on top of CS8421 with 2k
you need to switch off only crystal to bypass upscaller but you need to install crystall correctly as From datasheet of it
Old 14th December 2012, 12:32 PM   #25
The resistor above gives the oversampling multiplier,however you can make it a NOS DAC or NON oversampling dac by connecting the pcm1794 's SCK and BCK it can produce a non audible delay between channells butsound is better and can be corrected increasing one of the 2 resistors to BCK (sck ones shoud be removed)
Old 22nd December 2012, 01:44 PM   #26
Default another way of connecting pcm1794
just dont connect sck and bck if you want no delay
Old 31st December 2012, 07:43 AM   #27
Atomicmidi is offline Atomicmidi  United Kingdom
Are you selling these on Ebay?
DAC Dual Mono PCM1794 Kit DIY PCB 192kHz 24 32 Bit WM8805 24bit CS8421 | eBay
Old 20th February 2013, 12:26 PM   #28
focal7C is offline focal7C  Australia
Default I2S feed?
Is the WM8805 configured to be USB to I2S out - directly feeding the PCM1794?
Old 20th February 2013, 03:09 PM   #29
YES,if cs8421 then you can use even cm6631 32bit usb board
check schematics for resistor to bypass it,to use only wm8805 out format
Old 20th February 2013, 03:12 PM   #30
New boards on the way
V1.1 cs8421 wm8805 pcm1794 ,smaller pcb,better circuit,RED colour pcb
TPA6120 or TPA6120A2 headphone amplifier,improved dynamic range by decreasing load on I/V opamp, SMD HPF decoupling cap at the out of pcm1794-rest all hole mount components,leds for every stage of the DAC ,multiple connectivity options + analog switches
S.houBed DAC 132db Dual MONO pcm1794Hide this!Advertise here!
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
Dac Help, WM8805 + CS8421 + Dual mono PCM1794 xslavic Digital Line Level 2 11th August 2012 04:25 PM
Dac or Dual-Mono Amps? Reference1042 The Lounge 2 9th March 2012 12:38 AM
Dual Mono Twisted Pear Opus Modules/Complete DAC Hdale85 Swap Meet 2 2nd March 2012 07:03 PM
FS: Twisted Pear DUAL MONO OPUS DAC matthewm Swap Meet 20 11th July 2010 01:38 AM
Copyright ©1999-2017 diyAudio
