Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
S.houBed DAC 132db Dual MONO pcm1794
Old 11th November 2012, 10:53 AM   #11
Aiace is offline Aiace  Italy
Originally Posted by qusp View Post
all good, I just think its unnecessary. not suggesting you will get rich from this, just that it would be better if you didnt print false specifications on the PCB and on the thread title when you obviously dont know its actual performance.
The message was clear the first time you wrote it. Please let him describe more accurately his project and don't polemize on silly details.
Old 14th November 2012, 03:41 PM   #12
xslavic is offline xslavic  Moldova
another thing would be to aproximate the 51R resistor to be closer to the Out impedance of the opamp
Old 14th November 2012, 06:00 PM   #13
qusp is offline qusp  Australia
qusp's Avatar
you meassure yourself,i choosed the best in it and will try to improve it,i dont tend to get rich from this.
when someone makes a comment like this, its not clear to me the motivation for what I said was understood by HIM, obviously you understood it. I didnt repeat/clarify it for you....
it does the design a disservice as well, since it wont happen to meet the number
Old 17th November 2012, 03:51 PM   #14
Default S.houbed DAC
Use lm7805 backwards in the place of the lm317 and connect it as in datasheet
Old 17th November 2012, 04:15 PM   #15
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Yeah, even trying to accurately measure 132dB S/N requires some very expensive equipment, as far as I know.
Old 18th November 2012, 02:23 PM   #16
Default New,out low pass S.houbed
Hi
new improvement
valid for Active filter opamp
Calculated for opa2134 cuttof at 25.3khz
increase Q factor very Much > 10 times
1.replacethe first 6.8k with 250R(4times amp or 12db gain) to 1k(No gain-double Q factor)
2.replace the rest of 6.8k with 1k
3.replace the 102k and 7k5 use only one 1k or two in parallel total 1k
4.filter capacitor 172pf(its the one on the opamp end from the 2 res in parallel)
5.replace 1n with 230nF
if need other opamps claculate here:
(Sample)Multiple Feedback Low-pass Filter Design Tool - Result -
for caps if one is 220pf the other one is 180n
AND finally 180pf and 220n (220p and 180n) -you get same 25291.38Hz
you can even make it floating thats 2x220n
Old 18th November 2012, 09:19 PM   #17
Default error corrected s.houbed
the crystal had a bad connection
i guess i forgot to use it for the 4pin smd
Old 19th November 2012, 02:46 PM   #18
Default error 24.576 crystal
please correct before installing
Old 27th November 2012, 11:08 AM   #19
another solution for the single end LPF is to remove 110k and 7k5 and replace with only one 6k8 it will get you the same Q factor
Old 30th November 2012, 08:45 AM   #20
IMPORTANT
One more thing First test without transistors installed
connect 390/195R out (feedback res) direct to 51R out,it should work this way to
51R equal to opamp output impedance so no more pops and clicks
S.houBed DAC 132db Dual MONO pcm1794Hide this!Advertise here!
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
Dac Help, WM8805 + CS8421 + Dual mono PCM1794 xslavic Digital Line Level 2 11th August 2012 04:25 PM
Dac or Dual-Mono Amps? Reference1042 The Lounge 2 9th March 2012 12:38 AM
Dual Mono Twisted Pear Opus Modules/Complete DAC Hdale85 Swap Meet 2 2nd March 2012 07:03 PM
FS: Twisted Pear DUAL MONO OPUS DAC matthewm Swap Meet 20 11th July 2010 01:38 AM
Copyright ©1999-2017 diyAudio
