Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Does transport stability / jitter still matters ?
Old 23rd October 2012, 07:18 PM   #1
JdAo is offline JdAo  Portugal
Default Does transport stability / jitter still matters ?
Please enlighten me as I'm a few years behind...
With all the advancements on jitter correction and all on good DACs, is there still any advantage to having a good CD transport or jitter free source of digital files ?
Thank you
Old 24th October 2012, 08:36 AM   #2
s3tup is offline s3tup
s3tup's Avatar
For SPDIF...
1. It does matter if you recover the clock - no matter whether you use it directly in you DAC or thru ASRC.
2. It matters a bit if you use some sort of FIFO, depends on nthe FIFO length and algorithms used.
3. It doesn't matter if you sync the transport from DAC's local clock oscillator.
So... 1 is still very popular, 2 is coming but rather rare AFAIK. 3rd one... A bit in the transport+DAC combos with propertiary interface.
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 24th October 2012, 12:12 PM   #3
lcsaszar is offline lcsaszar  Hungary
The consensus is that transport servo operation draws high current peaks, and this spoils analog PSU voltage, that affects DAC and analog signal output. Low mechanical jitter needs less servo correction, hence less current, less PSU noise. But I have never seen any objective experimental proof of this theory...
Old 11th November 2012, 06:23 PM   #4
john dozier is offline john dozier  United States
john dozier's Avatar
I find this thread interesting as the digital signal is generated in the transport from the zero crossing in the rf eye pattern coming off of the cd. If this eye pattern is indistinct due to jitter, it would seem to me that this error could never be corrected even with the most sophisticated reclocking schemes. I am not a digital theorist and would like someone who is to chime in. Thanks
Evil looms. Cowboy up. Kill it. Get Paid.
Old 12th November 2012, 11:30 AM   #5
The transport jitter is corrected by writing the digital stream into an elastic buffer, and reading out by the low-jitter master clock. The average clock frequency (and CLV - constant linear velocity) of the transport is controlled by a PLL, also synchronized to the master clock. The error signal of the PLL is the transport jitter.
Separate transport - DAC is a problem, because the SPDIF is a one-way link, the master clock is not fed back to the transport...
Reclockig cleans jitter occuring in the digital processing chain between the elastic buffer and the DAC chip - not the jitter occuring in the transport.
Old 12th November 2012, 11:42 AM   #6
So improving the clock in the mechanism (in this case a CDpro2) should result in lower overall jitter. Did I get that right? Thanks and regards
Does transport stability / jitter still matters ?Hide this!Advertise here!
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
How do vibrations in a CD player/transport cause jitter ? percy Digital Source 18 7th April 2006 07:55 PM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
Best quality and lowest jitter Philips transport assembly? mburnstein Digital Source 8 13th January 2003 09:20 PM
Copyright ©1999-2017 diyAudio
