Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
cs43122 output stage, something went wrong
Old 30th October 2003, 03:28 AM   #1
Thomas Giz is offline Thomas Giz  United States
Default cs43122 output stage, something went wrong
This is question for jwb. I used his schema to build nice DAC with mosfet line driver output stage. Everything is OK but that output. Circuit built according to original schema. Weird things at least for me: power supply gives -/+ 14v but after it's connected to the circuit I measured at connector +14V and only -3.2V. Voltage between base and emitter of each transistor is at the level of 0.6V. Voltage accross D2 is 2.4V and 0.74V at D1. In other channel D2 has 2.16 and D1 0.97V.
Tried to increase supply voltage but no changes. The most terryfing is at the source of mosfet (output). I get 4 different voltages for +/- left and right. From 2.5V to 10V
Where should I start to fix that problem? Checked already connections - looks OK. I tried to match all components (R,C). What about the LEDs ? What voltage should they be? Need help, please .
Old 30th October 2003, 03:53 AM   #2
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Did you use the Rev A or the Rev B boards? There's a missing trace between two LEDs in the Rev A. Also two people have built the Rev B boards, and both of them had trouble soldering the voltage regulators. I had no trouble but it seems to be problematic.
Old 30th October 2003, 11:19 PM   #3
I should have mentioned that in my first post but from the circuit Rev B I took only output stage for cs43122. The chip DAC and receiver are placed on separate PCB of my own design and they work perfectly They have also different power supply than output stage.
1.I just wonder if I put correct LEDs 3.5V. Maybe they drain too much - I'm new in electronics field so for me everything is possible at least for now.
2.Maybe I damaged by solder heat some mosfets or transistors. How sensitive are they ?
3.What could be the reason for 10V output on one mosfet and 2.5V for the other.
Old 31st October 2003, 12:17 AM   #4
Me stupid use bad, bad power supply. After 2 hours of checking everything 3 times step by step I came to conclusion that circuit is perfect so .... I took two 9V batteries, connected them to the circuit and ... holy lord, it works.
So simple too difficult to find.
Thanks JWB for your time.
Old 31st October 2003, 12:33 AM   #5
jwb's Avatar
Glad to hear
If you can get any pictures we'd love to see them.
Old 31st October 2003, 01:19 AM   #6
of course I post some photos but now I have no camera and I'am still in progress of case building.
cs43122 output stage, something went wrongHide this!Advertise here!
cs43122 tube output stage help - based on cdenhancer II design ackcheng Digital Source 21 19th March 2006 03:37 AM
12v tube output stage for cs43122 based dac? mbcouple Tubes / Valves 10 14th August 2004 02:47 AM
cs43122 output stage Thomas Giz Digital Source 5 22nd October 2003 08:28 PM
Analog buffer/filter stage for CS43122 help KasperM Digital Source 6 2nd January 2002 11:32 PM
Transformer in analoge stage in DAC (cs43122) hifi Digital Source 0 17th May 2001 09:02 PM
Copyright ©1999-2017 diyAudio
