Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
PCM1704 Help needed with higher dc offset from one channel
Old 9th October 2012, 09:28 AM   #11
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
They are original and socketed, I swaped left for right but still had the 50mV on the same channel, it could be the layout of the right is making that side oscillate. Next time I have my scope out and hooked up I will check for oscillations.
PS thanks for the reminder of opamp stability
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 12th December 2012, 02:39 AM   #12
georgehifi's Avatar
Hi abraxalito, thank you very much for the dac dc offset nulling circuit it worked a treat, instead of 17mV left and 50mV right comming out of the OPA627 I/V's, now I have +- .1mV I don't know why but the sound has improved very much overhaul esspecially in the bass. Is this possible, that the OPA627 as an I/V does not like to see any dc comming into it from the dac/s???
Cheers George
Old 13th December 2012, 11:08 AM   #13
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Hi George - since you asked for my input I can only say scrap the opamp I/V if you're really concerned about SQ. Its really a waste of a decent R2R DAC chip. Go for something with more immunity to glitches as a post amplifier like a discrete JFET design, or use passive I/V and fierce passive post-filtering to remove all the RF. I've posted up a suitable filter schematic on my thread called 'Digital, but not by the numbers' in Digital Line.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
PCM1704 Help needed with higher dc offset from one channelHide this!Advertise here!
Zapfilter DC offset trouble, help needed Sarman Digital Source 35 12th February 2007 09:15 PM
Help needed: odd DC offset on UCD400. maxlorenz Class D 16 8th September 2006 06:08 PM
High DC Offset in one channel hifileslie Solid State 0 28th April 2006 03:53 PM
preamp dc offset channel difference? crippledchicken Solid State 3 30th June 2004 02:49 AM
Dang. 185mv DC offset in the right channel. GrahamnDodder Chip Amps 7 17th September 2003 08:47 AM
