Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th December 2004, 06:32 PM   #31
Bricolo is offline Bricolo  France
Bricolo's Avatar
you have to put the clock at the place at the original quartz, if your chip is recieving the clock signal from another ic, you can't simply put the KC at the 7327's input
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 17th December 2004, 06:32 PM   #32
Originally posted by arnaudb
Hi
I have a problem to solve.
I would like to put a kwak clock on my SAA7327 jolida JD100 controller.
The problem is that there are a clock-in and a clock-out pin on the SAA7327. I have only one output on my kwak clock.
I've looked at the SAA7327 data-sheet and it seems that this ic only work with crystals.
Is someone would have any clue ?
(Kwak) clock output normally goes to chip input (pin 16). Connect clock ground as close as possible to the SAA chip (preferably pin 14).
Please note that this chip runs on 3.3V, so the clock output voltage shouldn't be higher than that.
enjoy
Guido Tent
www.Tentlabs.com
Old 17th December 2004, 07:39 PM   #33
Banned
Send a message via Yahoo to Elso Kwak
Originally posted by JohnW
The simple fact is that the PCM1732 DAC (at least in SRC upsample mode) is operated from the 24MHz clock irrespective of the jitter attenuation abilities of the SRC.
No matter how good the transport section clock is, IT CAN NEVER BE BETTER then the DAC’s 24MHz Master Clock, as the DAC’s Master clock is the critical “Heart Beat” of the Digital to Audio conversation. The Jitter performance (Phase Noise) on the DAC’s master clock will take precedence over any proceeding "perfect" clock – this is an undisputable fact.
Therefore, with this essential fact in mind, the DAC’s master clock (24MHz) must be improved to a point where it is not the limiting factor. We could discuss until the cows come home the virtues of SRC jitter attenuation and re-latching the I2S data, but the significance of the quality of the Master Clock performance operating the DAC Audio conversion is an undeniable reality.
Both the transport's masterclock and the clock at the DAC are important I learned.
Old 17th December 2004, 07:45 PM   #34
Banned
Post KC feeding a 5V chip
enjoy
You can run the KC at +/- 3.3V but you must be aware that the comparator AD8561 does not put out 5V but typically 3.5V for a logic "high" voltage. So you need only a slight attenuation, if any, of the clocksignal compared with feeding a 5V chip.
Old 17th December 2004, 08:34 PM   #35
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
You could have the most perfect clock on the transport section (primary side of ASRC), however if the clock operating the secondary side of an ASRC which also operates the DAC is poorer then the primary side, the benefit of the better transport clock is significantly degraded.
The phase noise performance of an ASRC can never be better then the Secondary side Master clock. Put your best clock on the secondary side – then improve the primary side clock.
I find it frustrating, the some people cannot understand that in an ASRC system the DAC is ultimately Clock by the secondary side clock and the SRC will offer no attenuation to this clocks phase noise.
Notice I used the word “attenuation” – meaning the level of phase noise on the primary side is still important – but if you have a choice, add your second best clock here - its Phase noise will be ATTENUATED by the ASRC – so long as the ASRC secondary side clock is of LOWER PHASE NOISE.
In a typical system, the primary side clock (the transport clock) will be implemented as a part of the CD servo decoder i.e. form part of the crystal oscillator “block” on the CD decoder IC. Due to the very poor short term phase noise performance of these integral oscillator circuits – improving this clock will bring large benefits.
As most modern DAC’s and ASRC don’t have onboard crystal circuits (for good reason), they necessitate the use of a “off chip” clock circuit, and thus the secondary side clock will normally be of inherently higher quality.
So once again, best clock on ASRC Secondary side, second best clock on primary side of ASRC where it will gain the benefit of the SRC jitter attenuation.
Elso my hat off to you if that’s your Wife / Girlfriend in your avatar!
John
Life shouldn’t be take it too seriously, you will not come out alive anyway…
Old 17th December 2004, 09:24 PM   #36
Banned
Talking Avatar
John
John, beauty is only in the eyes of the beholder....
Old 17th December 2004, 11:28 PM   #37
Elso: That's the nicest thing i have heard you say
btw: my avatar was found on www.bride.ru And of course it is my wife / girlfriend
(soon ... )
www.newclassd.com
Old 18th December 2004, 04:15 AM   #38
Banned
Post Beauty is only in the eyes of the beholder
Lars, just have a look here:
http://www.dailybruin.ucla.edu/db/is...ws.beauty.html
http://news.bbc.co.uk/2/hi/africa/3561878.stm
http://www.fullhyd.com/discussions/v...=39085&start=0
Old 18th December 2004, 10:22 AM   #39
Banned
Lightbulb Salvation
(soon ... )
Lars,
On second thought you better find salvation here:
http://www.subgenius.com/?
Clean Master Clock distribution UV101 Digital Line Level 1 3rd April 2009 07:37 PM
Tapping master clock habsrock93 Digital Line Level 10 8th November 2008 01:41 AM
Master clock of Marantz SA8260 hatasa Digital Source 7 29th January 2004 09:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
